Is eg stock exhaust pipe not high flow enough?
Old Sep 8, 2007 | 12:06 AM
crazyguy's Avatar
Default Is eg stock exhaust pipe not high flow enough?
i have a b16a swap in the eg civic.i am running a aftermarket ss dc header with aftermarket air intake.but with stock eg exhaust pipe and cat converter,but i have a oem s2000 rear end muffler welded on.but is eg stock pipe not high flow enough and holding the car back?thanks
Old Sep 8, 2007 | 12:29 AM
JDMDAEK's Avatar
Default Re: Is eg stock exhaust pipe not high flow enough? (crazyguy)
stock exhaust is always enough flow bro. its only a four cylinder. just sit back and listen to your vtec blast
Old Sep 8, 2007 | 07:56 AM
92civicx's Avatar
how many inches is it?
Old Sep 8, 2007 | 08:05 AM
EG8R's Avatar
Default Re: Is eg stock exhaust pipe not high flow enough? (92civicx)
b16 exhaust is 2" i believe.
Old Sep 8, 2007 | 08:22 AM
Amped's Avatar
Default Re: Is eg stock exhaust pipe not high flow enough? (EG8R)
i would say get a higher flow if you want a little more power but it would be kinda loud.
Old Sep 8, 2007 | 08:34 AM
lilo_goki's Avatar
u need a aftermarket full exhaust system to make that car run better and a good ecu tune.
All_Motor_Moh
Jun 23, 2007 09:14 PM
Sir_Wallace
Sep 5, 2006 09:57 AM
StolenTeg
Sep 4, 2006 01:37 PM
andrew dc
Jan 17, 2003 06:53 PM
