D15 injectors work in a D16A6?
Well I'm about to swap out my D15 with a D16A6. But my D15 has (almost) new injectors in it and I have no idea how old the D16A6 injectors are so I want to swap them. Is this possible?
I'm not 100% sure, and don't quote me on this, but I think most, if not, all, honda injectors are the same for the generation. I guess test fit, and if it seems to go in correctly, and doesn't "scrunch" up the o-rings, and it runs fine and everything, then it should be a-ok. If all else fails, just get some stock injectors for the d16...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 »</TD></TR><TR><TD CLASS="quote">It is a DPFI, can anyone confirm that the DPFI injectors don't work in the D16A6 MPFI.</TD></TR></TABLE>
well for one, there are only two injectors...and no, they are not the same.
No, you cannot mix DPFI injectors with an MPFI setup.
yeah no u cannot mix the dpfi with the mpfi's i took them outa the d15 intake mani and they are so much different, u cant even change the clips to use them.. You got to get mpfi injectors.
slow02ss camaro
Dec 9, 2003 04:02 PM
