DC2 Front Brakes on an EF
Has anyone used DC2 front brakes on an EF chassis yet?
I tried searching and all i found was this... which was pretty much useless
https://honda-tech.com/zerothread?id=1296125
I have the 4040 prop valve and I plan on upgrading my BB and MC to the DA ones. Also, I am currently running the DA rear discs.
I was planning on using only the front spindles and calipers and not the knuckles.
So, will I run into any problems when using the EF knuckles on the DC2 spindles? Is it even possible to run this setup?
DC2 calipers will bolt straight up to DX front knuckles. Just use a T25 caliper brackets, ex size rotors and your set. On a side note if you use a 89 prelude M/C it will bolt up to your stock EF B/B. But all this is all in the FAQ's:
https://honda-tech.com/zero...age=1
v-motion
May 24, 2008 07:02 AM
