b&m short shifter
the instructions say i have to take the exhaust pipe and the cat to install a short shifter do i have to do all this or is there another way? Another question how do i remove the shifter console????? Help is appriciated and no dum *** answers.
Here you go.
The install is for a EG Civic but its basically the same.
Don't mean to be rude but next time try a Search.
https://honda-tech.com/zerothread?id=1007935
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicoya_hyphy@yahoo.com »</TD></TR><TR><TD CLASS="quote">thanks</TD></TR></TABLE>
No problem.
Hope it helps you out.
No problem.
I installed mine a few weeks ago, the easiest way i saw to do it without taking the exhaust apart was after unbolting the shifter from the shift linkage, unbolt the shift extension rod on the transmission side (just one bolt) and pull the whole thing out with the shifter attached.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superchi »</TD></TR><TR><TD CLASS="quote">I installed mine a few weeks ago, the easiest way i saw to do it without taking the exhaust apart was after unbolting the shifter from the shift linkage, unbolt the shift extension rod on the transmission side (just one bolt) and pull the whole thing out with the shifter attached. </TD></TR></TABLE>
This is what I did when I installed a short shifter in my friend's car.
warchieft2k
Nov 24, 2006 09:02 PM
superbeastcrx
Sep 13, 2005 06:09 AM
