d15b transmission question
Old Sep 7, 2007 | 05:45 PM
mugenef9's Avatar
Default d15b transmission question
ok i have a d15b engie that the trans went bad on. i got a different trans out of a 90 hf i believe and the splines arent the same what tranny can i use to solve this problem
Old Sep 7, 2007 | 05:53 PM
dr_latino999's Avatar
Default Re: d15b transmission question (mugenef9)
It sounds like you have an 88, so you'll need another 88 transmission if you want to retain the same clutch.
Old Sep 7, 2007 | 06:10 PM
mugenef9's Avatar
no its the jdm d15b out of a eg i believe what cable trans bolts up to that
Old Sep 7, 2007 | 06:33 PM
dubzz24's Avatar
Any 88-2000 d series tranny will bolt up to it. It's not about the motor, it's about your clutch / tranny combo. If your tranny is from an 88, then you need to use a clutch / FW from an 88.
So basically if your current tranny is an '88 you're going to want to find an '88 to replace it, or else you'll have to swap the clutch and FW to the same year as whatever tranny you get.
Modified by dubzz24 at 7:57 PM 9/7/2007
Old Sep 7, 2007 | 06:52 PM
abram_quito's Avatar
D SERIES = D SERIES PARTS
B SERIES IS DIFFERENT
Old Sep 7, 2007 | 06:54 PM
dubzz24's Avatar
Default Re: (abram_quito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito &raquo;</TD></TR><TR><TD CLASS="quote">D SERIES = D SERIES PARTS
B SERIES IS DIFFERENT</TD></TR></TABLE>
Please learn more before you post more useless crap.
Old Sep 7, 2007 | 09:24 PM
mugenef9's Avatar
ok thanks alot thats what i was looking for
dylananderson
Aug 24, 2014 12:30 PM
sireg6
Feb 28, 2007 05:45 AM
rice a roni
Apr 5, 2006 08:46 AM
cbmprelude
Nov 8, 2005 03:31 PM
ahc'monracing
Feb 5, 2003 06:34 AM
