quesiton about tire size on 18 inch rims on my type S
Old Sep 7, 2007 | 04:09 PM
mraza's Avatar
Default quesiton about tire size on 18 inch rims on my type S
Im running 225/35/18's on my 18 inch rims. My car is lowered with tein spirings 1.4F and 1.3 rear. Right now whenver I go on big bumps or pot holes, I hear a loud noice in the car. Im thinking its the tires, since they are 35's ( Car runs fine on stock tires)... Is anyone else having a similar problem? if i chang my tires to 40 would it make a difference??? Also another related question is would a 225 45 18 fit on the RSX with 18 inch rims?
thanks
Old Sep 7, 2007 | 11:21 PM
JCL's Avatar
JCL
could it be ur shocks since u r on springs? whats the offset of ur rims? im on 18x8 + 40 with 225 40 18 and no problems at all.
Old Sep 8, 2007 | 01:19 AM
Aco512's Avatar
Default Re: quesiton about tire size on 18 inch rims on my type S (mraza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mraza &raquo;</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>that may be a problem
it could be a litter too large for that drop
i do not know for sure
but i have 225/45/17, adding another inch to it would be too risky on my part
although i'm on sportlines
wouldn't be worth the risk
Old Sep 8, 2007 | 07:28 AM
mraza's Avatar
Default Re: (JCL)
hi, thanks for the input guys, Im running 18 X 8.5 on a 42 offset. Maybe its the shocks cause they are stock, but I only had the springs on for about a year and the car has 53000 miles, so I don't know if the shocks would go bad that quick unless they don't respond to tein springs that well to begin with. I was thinking it were the tires cause the profile is way too low 35. usually its the setup for 19 inch wheels.
Old Sep 8, 2007 | 10:11 AM
Todd00's Avatar
I said I don't want a title!
Default Re: (mraza)
I can pretty much guarantee that your OEM shocks are done. Plus, you have, more than likely, heavy 18" wheels on there. Both will contribute to a crappy ride because your shocks aren't up to controlling the springrate.
Old Sep 8, 2007 | 10:58 AM
mraza's Avatar
Default Re: (Todd00)
hi, i ve got axis Hiro rims on my car.. they rn't too heave probably 22 lbs each.....
maybe ur right about the shocks..
thanks
BAYxlude88
Dec 14, 2008 11:00 AM
07rebel
May 11, 2007 07:52 AM
SF-Rsx
Sep 14, 2006 10:00 PM
INTEGRA_LS
Dec 6, 2003 10:17 PM
Rio
May 21, 2003 04:24 PM
