6th Gen electrical question. Pls help
I've got a 2000 Accord EX Coupe 2.3L, and I'm looking for a O2 simulator for the rear O2 sensor so I can change my cat.
Where can I get one? Is there any custom made for the Accord?
Modified by nightwind at 4:29 PM 9/7/2007
Modified by nightwind at 4:30 PM 9/7/2007
I pulled this from another forum but this should take care of your problem.
yup, we did this for a grand total of $3.99+tax i believe!
get this "help" part at your local parts store: 18mm defouler - comes in a pack of 2
here's the package and the two defoulers screwed together
i drilled out the bottom of one with a 1/2 inch drill bit - go slow, use lots of oil, it's thick
i don't have any pictures of the one drilled out alone, but here's two pics of the final product, one from the bottom one from the top. in the second pic you can see how it was drilled. the drilliing is done to be able to fit the o2 sensor thru the 1st defouler.
final product all installed, and skabone confirms "it works!!"
had to persuade the heatshield slightly to clear the new longer o2 sensor but that's no problem.
m0t0rhead
Oct 28, 2004 05:35 PM
iam7head
Apr 28, 2003 11:56 AM
