ITR cams ?
Old Jun 15, 2002 | 08:58 PM
yellowbuffalo's Avatar
Default ITR cams ?
If i added ITR cams to my engine would i need to install stiffer springs, retainers etc??? And would this raise my redline?
Old Jun 15, 2002 | 09:04 PM
comptechgsr's Avatar
Default Re: ITR cams ? (slipknot23)
no you would not.
the only way to raise ur redline is to change/modify ur ecu---then u would need a valvesprings if any----
not so sure on the retainers tho buddy
Old Jun 15, 2002 | 09:05 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ITR cams ? (comptechgsr)
If ur gonna add ITR cams, get the ITR springs and retainers and a new ECU with higher redline. Better safe than sorry.
Old Jun 15, 2002 | 09:48 PM
Default Re: ITR cams ? (Rguy)
well if i add retainers, springs and whatever shouldnt i just go after mnarket?
Old Jun 15, 2002 | 09:50 PM
01PYITR's Avatar
R cams make alot of power when tuned properly.
Old Jun 16, 2002 | 07:01 AM
Racebrewer's Avatar
Default Re: ITR cams ? (01PYITR)
The ECU controls your redline (as was pointed out). If you don't want to change your ECU go with cams that put the power where you can use it.
If you change out your ECU, the sky is the limit and that is where the cost factor goes, too.....
Research, research, research.....
John
Old Jun 16, 2002 | 07:43 AM
stick's Avatar
do a search since this subject has been covered alot
but all u do is drop in the ITR cams no need for valvetrain or retainer upgrade.
u will keep stock redline
may think about some type of vtec controller to raise ur xover to take advantage of the ITR cams
Jowee
25
Aug 29, 2020 02:43 PM
4door-si
May 13, 2011 10:14 AM
H2nr
Mar 19, 2004 07:54 AM
dLo GSR-stolen-now-WRX
Nov 18, 2002 09:03 PM
cr00klyn718
Mar 17, 2002 02:39 PM
