Power Steering SOHC DOHC Question.
Old Sep 7, 2007 | 10:15 AM
HondamanXxX's Avatar
GO GIANTS!
Default Power Steering SOHC DOHC Question.
Would a SOHC Power Steering pump work with a JDM DOHC engine? My only consern is the belt on the DOHC pulley. Anyone try it before?
Old Sep 7, 2007 | 11:11 AM
95ProjectEJ1's Avatar
Default Re: Power Steering SOHC DOHC Question. (HondamanXxX)
bump for an answer and clarification
I now know that you need to use a Dseries ac compressor with a Del Sol/CRV bracket, but for the PS im confused. I think you need the Bseries PS unit...
Old Sep 7, 2007 | 11:13 AM
GO GIANTS!
Default Re: Power Steering SOHC DOHC Question. (95ProjectEJ1)
The reason why I didn't use a my B series one is because it wouldn't fit correctly. I would have to bend my SOHC P/S line to make it fit.
Thanks for the bump
Old Sep 7, 2007 | 11:16 AM
drtysohc's Avatar
i'm almost positive that you have to use the b series PS pump. it should all bolt up and work
Old Sep 7, 2007 | 11:17 AM
GO GIANTS!
Default Re: (drtysohc)
That line was giving me a hard time. I was about to heat it up a little with a tourch to bend it a little.
Old Sep 8, 2007 | 05:33 PM
GO GIANTS!
Default Re: (HondamanXxX)
bump
Old Sep 8, 2007 | 05:36 PM
pdiggitydogg's Avatar
read through this thread:
https://honda-tech.com/zerothread?id=1822781
theres a post, further down, where someone explains they used a d series pump....
(i sure wouldnt)
Old Sep 8, 2007 | 05:37 PM
Luserkid's Avatar
92-95 any integra pump will do.
96-00 SI pump will do.
You could make a custom bracket (i did for a friend) but thats up to you on how much fab skills you think you have.
Old Sep 8, 2007 | 05:41 PM
GO GIANTS!
Default Re: (Luserkid)
Well right now I have everything hooked up. It squeeks like hell and I think its because the belt is stopping. When this happens I loose my power steering. I was thinking it's the belt. idk mannn...
Thanks for the link pdiggitydogg
Old Sep 8, 2007 | 05:50 PM
Are you sure you just dont have enough tension on the belt?
Old Sep 8, 2007 | 06:25 PM
GO GIANTS!
Default Re: (pdiggitydogg)
Thats what I will be checking tomorrow morning. Hope thats the problem rather then something else.
Thanks
guessohw
Nov 4, 2011 02:06 PM
wiz321654
Dec 5, 2006 08:17 PM
smash fascism
Oct 4, 2005 03:45 PM
blackie
18
Jul 4, 2005 11:50 AM
aeolus
Aug 5, 2002 11:37 PM
