turn signals wont work...
ok so signals arent working....no blinking on the cluster, but the hazards do work...what i've tried...changed the bulbs, changed the fuses, changed the combo switch, changed the hazard switch, changed the signal relay aka flasher...im absolutely stumped...the next thing i might do is completely rewire the signals....and i've searched for hours on here and threads dating back to 4 years ago never had any answers...
so if anyone has any insight ideas or knows wtf happened, please let me know
have had same problem... i had some corrosion on the metal connectors inside the plastic housing where the bulb connects too...cleaned it wit some toothpaste and coke ...then it worked just fine... good luck
flatblack-h22
Dec 4, 2006 01:39 PM
