Lower Ball Joints?
Old Sep 6, 2007 | 10:10 PM
Jizzo's Avatar
Default Lower Ball Joints?
My 93 Civc is startin to squeel like crazy when i ride and turn and I believe its the lower front ball joints... I tried gettin the part from a junkyard but they only pulled out the lower control arm for me... So I basically bought the wrong part... Then I was told that it would be difficult to take out the lower front ball joints and replace them... I found some on ebay for pretty cheap and I would like to know what my options? From the looks of it... It seems like I should buy the whole assembly connected with the lower control arm all the way up to the upper control arm...
Old Sep 7, 2007 | 12:14 AM
BlueIntegraBoy's Avatar
Default Re: Lower Ball Joints? (Jizzo)
I bought lower balljoints from eBay. Cheap and does the job. Had them on for over a year and no problems.
Old Sep 7, 2007 | 11:34 AM
Jizzo's Avatar
Default Re: Lower Ball Joints? (BlueIntegraBoy)
is it hard to install the lower ball joints?
Old Sep 7, 2007 | 11:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jizzo &raquo;</TD></TR><TR><TD CLASS="quote">is it hard to install the lower ball joints?</TD></TR></TABLE>
It is suggested that you press them into the knuckle, but it can be done with lots of lubrication and a mallet.
Old Sep 7, 2007 | 11:48 AM
instructor74's Avatar
You can also put the ball joint in the freezer for a few hours then heat up the knuckle with a propane torch. Once its good and warm drop the cold ball joint through the knuckle it should go right in.
Old Sep 12, 2007 | 07:45 PM
Jizzo's Avatar
Default Re: Lower Ball Joints? (instructor74)
thanks... but how do i take out the lower ball joints?
Old Sep 12, 2007 | 07:49 PM
civiceg94's Avatar
take a big hammer. and hit the sucker out. thats what i did. hopefully your strong enough
stock_honda_coupe's Avatar
Big hammer. They might have a C clip holding them in too.
Old Sep 12, 2007 | 07:53 PM
civiceg94's Avatar
o yeah for got to mention the c clip. take that out and then give it all you got.
Old Sep 12, 2007 | 07:58 PM
yoffer's Avatar
Banned
It could be your upper strut bearings making the squeeling noise. Maybe you should replace your struts. I've never really heard anything about lower ball joints making any sorts of noise. Note* Ball joints are covered in grease/lube and tend to be very quite.
Old Sep 13, 2007 | 05:23 AM
Default Re: (yoffer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer &raquo;</TD></TR><TR><TD CLASS="quote">It could be your upper strut bearings making the squeeling noise. Maybe you should replace your struts. I've never really heard anything about lower ball joints making any sorts of noise. Note* Ball joints are covered in grease/lube and tend to be very quite. </TD></TR></TABLE>
93 Civic don't have upper strut bearings they are a double wishbone suspension. Question what happens when the grease become contaminated or drys out. Lets just say they start to squeak and get play in them. Remember this car is 14 years old
Old Sep 13, 2007 | 07:17 AM
instrument's Avatar
my tires squeel, i've never heard of a ball joint producing a noise....and i don't see how it's possible seeing a balljoint doesn't really MOVE at any point.
Old Sep 13, 2007 | 08:10 AM
King V's Avatar
Default Re: (instrument)
They will squeak because they rotate inside the cup which is pressed into the knuckle and the "stud" is clamped in place where it attaches to the control arm. I used an air hammer from the bottom of the knuckle(stud end of the balljoint) and rapped it right out.
Old Sep 13, 2007 | 08:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">my tires squeel, i've never heard of a ball joint producing a noise....and i don't see how it's possible seeing a balljoint doesn't really MOVE at any point.
You really need to do some reading and watch some video of a suspension in motion. The ball joints does a ton of moving. it has to allow for movement of the suspension in a ton of different directions all the time and not bind to give the drive control of the car.
Old Sep 13, 2007 | 12:57 PM
Jizzo's Avatar
Default Re: (instructor74)
thanks!
Old Sep 13, 2007 | 12:58 PM
Jizzo's Avatar
Default Re: (civiceg94)
thanks!
Jizzo's Avatar
Default Re: Lower Ball Joints? (stock_honda_coupe)
thanks!
Old Sep 13, 2007 | 03:43 PM
vrrodri's Avatar
where on Ebay did you get the ball joints from? were they OEM?
Old Sep 13, 2007 | 06:06 PM
A ball joint will definately squeek if the greese leaks out through boot and the joint becomes dry.
Old Sep 14, 2007 | 07:47 AM
Jizzo's Avatar
Default Re: (stock_honda_coupe)
thanks for the info!
coojoe59
Jun 9, 2008 05:37 PM
androide016
Jan 8, 2008 11:10 AM
8_6 luder
Jun 22, 2007 03:31 PM
jojowasha
Jan 14, 2007 01:49 PM
novic3
Aug 19, 2006 08:34 PM
