Car idles way too high
Old Sep 6, 2007 | 06:10 PM
95sloweg's Avatar
Default Car idles way too high
I got a friend that just swaped a b16a2 in his 92 hatch. When he turned it on it idles way too high. The throttle cable is set how its supposed to be. So is there anyone with ideas as to why it idles way too high. Also what rear motor mount should he use?
Old Sep 6, 2007 | 06:12 PM
Murk 'EM's Avatar
Default Re: Car idles way too high (95sloweg)
check air bypasses in the tb.. double check the throttle cable... and use a 94-01 gsr mount
Old Sep 6, 2007 | 06:28 PM
95sloweg's Avatar
Default Re: Car idles way too high (95_acc0rd)
that could be a likely reason. anyone else with any other ideas?
Old Sep 6, 2007 | 06:35 PM
ek9 citrus's Avatar
Where does the motor idle? How high is too high?
Old Sep 6, 2007 | 06:36 PM
95sloweg's Avatar
Default Re: Car idles way too high (ek9 citrus)
Idles around 4-5k
Old Sep 6, 2007 | 06:40 PM
Murk 'EM's Avatar
holy **** thats not an idle thats a rev damn....... defnialy check those... its all it really can be. does it start up and go straight to 4-5 or does it bounce between there
Old Sep 6, 2007 | 06:41 PM
95sloweg's Avatar
its starts rough. then it revs up after like 5-10 secs(by itself), and once it gets there it doesnt come down, cause we eventually turn it off after a while.
Modified by 95sloweg at 10:55 PM 9/6/2007
Old Sep 6, 2007 | 07:00 PM
Murk 'EM's Avatar
check your maps and tps and all the passages in the tb and the throttle cable... if you dont find anything there tow it to a shop
Old Sep 6, 2007 | 07:02 PM
95sloweg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_acc0rd &raquo;</TD></TR><TR><TD CLASS="quote">if you dont find anything there tow it to a shop</TD></TR></TABLE>
That is one thing we hope to not do, but since it got late here, we will check all that tomorrow. Also, even if we did take it to a shop, what would they do different or look for.
Old Sep 6, 2007 | 07:05 PM
Murk 'EM's Avatar
nothing but then youd have there input
Old Sep 6, 2007 | 10:13 PM
team_work's Avatar
do you have an intake on it? i got an ls/v swap in my eg and it does that when i took off the intake. there is a small hole on the throttle body that if its not covered up will cause the car to do that. the rubber connector to the intake will cover it up and it will idle normal. if thats not it then check what these other guys said. my $0.02
Old Sep 8, 2007 | 09:11 AM
ek9 citrus's Avatar
Ok same **** happend with me, replaced my t/b they said it was an type r but it was really an LS, and my **** ripped about 4-5 and kept rising and once i turned it off it was rough *** hell so, i changed out my throttle to an BBK with all new sensors, but if u want an oem replacement go with an type r,b16, b18c1, no LS. Hope this helps you out and make sure your throttle cable is not too tight, and if you fucked with the spring coil that controls the throttle valve make sure its back on the right way because it if its too loose it will rev low at first an once you step on it it will stay at the last rev you were on but if you put the sprijng coil on way too tight then your going to have one hell of a time to push your accelerator.
Old Sep 8, 2007 | 06:37 PM
95sloweg's Avatar
it turned out to be just the Throttle cable. thanks for all the input.
Old Sep 8, 2007 | 06:40 PM
ke98248's Avatar
Old Sep 8, 2007 | 06:47 PM
egsr92's Avatar
ROFL!! I was gonna piggyback on that and say my gsr hatch idles too high, but my "too high" is 1500 for a minute and then it goes down to a healthy 600-800. Crazy
Old Sep 8, 2007 | 06:50 PM
ke98248's Avatar
Default Re: (egsr92)
that's what my car does.. lol
Old Sep 8, 2007 | 07:00 PM
95sloweg's Avatar
Default Re: (ke98248)
we had checked it in the beginning, but i guess we didnt check good enough. cause when we took the intake off, the throttle was opened, when the car was off. so thats how we figured that the cable was too tight. my cable on my hatch also needs to be adjusted.
Old Sep 8, 2007 | 07:08 PM
ke98248's Avatar
Default Re: (95sloweg)
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
crxnonvtec
22
Sep 3, 2009 02:52 PM
Hackura
Mar 12, 2009 03:17 PM
tigerjuice
Aug 8, 2007 03:19 PM
scrubachu
Apr 9, 2005 05:40 AM
