d16a6 into crx hf
Old Jun 15, 2002 | 06:09 PM
slowman's Avatar
I took way too long
Default d16a6 into crx hf
if i have the crx hf, would the d16a6 just bolt right in? what all would be required in doing this? i want to make a mini me setup so i am figuring out some odds n ins. thanks.
Old Jun 15, 2002 | 10:58 PM
slowman's Avatar
I took way too long
Default Re: d16a6 into crx hf (SeeOurX)
ttt
Old Jun 16, 2002 | 07:08 AM
red civic standard's Avatar
yes, everything would just plug in if you keep the HF tranny. You could use the wiring harness from the D16A6 or from your HF engine. Just make sure you use an Si ecu (email me if you need one).
If you want to use the Si tranny, you will have to use the axles for the Si (they are slightly larger) and therefore upgrade your hubs to the si ones. Hope this helps.
koolme88
23
Oct 6, 2011 12:46 PM
donaldmejr
Aug 28, 2005 03:10 PM
91HATCH
23
Oct 15, 2002 05:03 PM
IamVtec
Aug 29, 2002 01:26 PM
jrcrx
Jun 2, 2002 10:30 PM
