RPM drop and idle problem
Old Sep 6, 2007 | 05:06 PM
imperialcustoms's Avatar
Default RPM drop and idle problem
i just swaped a JDM DOHC F22 into my car it starts up and idles up and down i can figure that out ill clean the iacv and check vacume lines,but the real problem is after driving for about 3min wutever gear im in my RPMS drop to under 3gs and cuts out if i try and go any higher i was gonna replace the Map because my last moter i blew up and covered everything in oil. also im running a P14 ECU from an H23 dont no if that has anything to do with it, and aslo my cel doesnt work if anyone can help.. Thanks
Old Sep 7, 2007 | 07:31 PM
Default Re: RPM drop and idle problem (imperialcustoms)
ok so i decided to use my chipped LS ECU, and block my egr and disconect my secondary butterflies and everything is working great
amaq
Jun 25, 2010 05:51 AM
immalooser
Feb 18, 2009 05:23 AM
righteyeblind
Jan 2, 2008 10:13 PM
sleepyEK
Sep 6, 2005 01:40 PM
stRtypR25
Jan 12, 2003 03:09 PM
