Bulb grease for wire / wiring harness connectors lube?!? If not, what's best?
I cleaned my interior cabin wire harness and would like to lube the connectors again. I didn't wet them down with water, just a rag with some cleaner. Is the bulb grease best for this? If not, what's a good lube for the harness. I have white grease (paste in a tube) and lithium grease (spray which turns to paste). No bulb grease, but will get some if it's best.
Thanks for any input
You can use dia-electric grease. I use it on batt terminals and other connections.
GeoffCB7
Mar 28, 2013 11:47 AM
