'95 Accord Noise
Old Sep 6, 2007 | 03:13 PM
clh2991's Avatar
Default '95 Accord Noise
Well, I posted a topic about this before, but I can't find it now.
When letting off the accelerator in my '95 accord LX, I get a noise that starts out high and turns into a low grinding noise. (Sounds like a metal on metal noise perhaps) However, this only happens when I'm going over 50mph. Any ideas as to what it could be? I've already checked the exhaust, and it's not rusted out and the hangers are all intact.
Also, I forgot to mention that the noise stops when I apply the brakes. (No ABS)
Thanks in advance,
Chris.
Modified by clh2991 at 5:15 PM 9/6/2007
Old Sep 7, 2007 | 02:26 PM
clh2991's Avatar
I read that the mid-exhaust gasket is known to cause problems in the 94 & 95 models. Anybody know anything about it?
Old Sep 7, 2007 | 03:07 PM
BlUAc's Avatar
Default Re: (clh2991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clh2991 &raquo;</TD></TR><TR><TD CLASS="quote">ct.
Modified by clh2991 at 5:15 PM 9/6/2007</TD></TR></TABLE>
not to be a dick but have you inspected the brakes
Old Sep 7, 2007 | 04:12 PM
clh2991's Avatar
Yes, the brakes have been inspected.
The noise itself seems to come from the center of the floor in the rear of the car.
Old Nov 22, 2008 | 01:02 AM
slammed4thgen's Avatar
where are you located? i could check it out with you.
Old Nov 22, 2008 | 03:35 AM
P_Adams's Avatar
I would suggest inspecting the heat shielding for the exhaust system; particularly the converter shield. The upper portion sometimes breaks loose (or corrodes over time) and set up a horrendous noise at certain rpm ranges.
I would also confirm the systems' alignment. It could have a proximity problem....
P
Old Nov 22, 2008 | 09:44 PM
clh2991's Avatar
P
Seems like corrosion of the shielding could be a reasonable solution, as the problem was intermittent to begin with, and anymore, it doesn't happen.
RicerJake
Apr 11, 2016 10:23 PM
campfire
Mar 8, 2011 10:36 PM
ddolezal
Mar 30, 2008 11:03 AM
kaliATR
Mar 29, 2007 01:52 PM
piMpsCoTTiE
May 24, 2005 01:19 AM
