DOHC ZC swap?
Old Sep 6, 2007 | 03:09 PM
dylokjai's Avatar
Default DOHC ZC swap?
My current 4 dr dx has AC and i do not want to remove the AC when doing the swap is that possible?
Old Sep 6, 2007 | 03:29 PM
wiZCo's Avatar
Stouts 'n' Scotch
Absolutely, it just may make the swap a hair more time-consuming. All of your stock components will bolt up just fine to the DOHC ZC.
To keep the A/C in while doing the swap (without discharging/recharging), you'll have to unbolt the compressor from the motor and use wires to tie it out of the way.
If you're going to run an aftermarket header, you may have to get a slim fan to replace your stock A/C fan.
Hope that helps.
miguey310
May 16, 2009 01:28 AM
myJDM89EF
Sep 12, 2005 11:05 AM
cbp_crx
Jun 20, 2005 11:51 AM
virginia_dude
Jan 28, 2002 10:13 AM
91ReXSI
Nov 18, 2001 01:40 PM
