diesel motor oil
Old Sep 6, 2007 | 01:57 PM
ToeJam's Avatar
Default diesel motor oil
who uses it and why?
Old Sep 6, 2007 | 03:54 PM
slowcivic2k's Avatar
Default Re: diesel motor oil (ToeJam)
Probably diesel trucks, because that is what the manufacturer recommends....
Old Sep 6, 2007 | 04:24 PM
BigMoose's Avatar
I do. Shell Rotella T 10w30 in two civics, one accord, two Tahoes, one Yanmar diesel mower, Shell Rotella T 15w40 in one ford diesel backhoe, one case dozer and one kobelco track hoe. I also like Fleet Charge antifreeze, its used in all the above. Search on my user name, I've posted on both before.
I like the old ci rated Rotella T, it has more zinc antiwear additive. The jury is out on the cj, triple protection Rotella T, the new stuff with lower zinc. Time will tell. Great dino oil.
Old Sep 6, 2007 | 04:53 PM
ToeJam's Avatar
Default Re: diesel motor oil (BigMoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose &raquo;</TD></TR><TR><TD CLASS="quote">I do. Shell Rotella T 10w30 in two civics, one accord, two Tahoes, one Yanmar diesel mower, Shell Rotella T 15w40 in one ford diesel backhoe, one case dozer and one kobelco track hoe. I also like Fleet Charge antifreeze, its used in all the above. Search on my user name, I've posted on both before.
I like the old ci rated Rotella T, it has more zinc antiwear additive. The jury is out on the cj, triple protection Rotella T, the new stuff with lower zinc. Time will tell. Great dino oil.</TD></TR></TABLE>
Thank you.
Anyone else?
Old Sep 6, 2007 | 08:48 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToeJam &raquo;</TD></TR><TR><TD CLASS="quote">
Thank you.
Anyone else? </TD></TR></TABLE>
No need. He's right. It's very good oil.
ejprimo's Avatar
it is actually called a heavy duty engine oil which is suitable for both gas and diesel engines.
Old Sep 11, 2007 | 04:44 PM
BigMoose's Avatar
Default Re: diesel motor oil (ejprimo)
Or a "mixed fleet" oil.
Chevron Delo is very good also.
Old Sep 11, 2007 | 11:16 PM
ToeJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose &raquo;</TD></TR><TR><TD CLASS="quote">Or a "mixed fleet" oil.
Chevron Delo is very good also.</TD></TR></TABLE>
Thank you I read your posts. GREAT INFO!
Old Sep 12, 2007 | 08:34 AM
Furyof4's Avatar
I'm just finishing up my first drain interval with amsoil series 3000 5w-30 HDD. Its in a 6000 mile old mild b16a which, like all bvtec's, burned a little oil when used in vtec for extended periods w/ regular dino oil. For the first 4000 miles with the HDD (including 2 trackdays and 2 autox) oil cunsumption completely disappeared. In the last 1k miles the oil finally turned a slightly darker shade and has burned up a very small amount. I will be refilling with this stuff again for sure.
https://www.amsoil.com/storefront/hdd.aspx
jdmb18cman
May 15, 2007 01:56 PM
SoyMilk
Apr 19, 2007 06:14 AM
vtecaccord 1
Dec 8, 2004 08:11 AM
importtuner
Feb 22, 2004 06:08 AM
Drews Bitch
Jul 21, 2003 07:57 AM
