Need torque specs! 1997 Accord!
sorry, don't know, but go to helminc.com and buy a repair manual if you plan to continue to mod/repair your car, or for now try going to your local auto parts store to see if they have it. you can also see if your local library has the "alldata" database.
This is from the Haynes Manual for a 94-97 Accord...
*ALL IN FT lbs
(front)
Upper control arm ball joint nut=32
Upper control arm pivot bolt/nut=22
Steering knuckle lower ball joint but=40
Lower control arm inner pivot bolt=40
Tie-rod end to steering knuckle nut=32
*ALL IN FT lbs
(front)
cmb7684
Nov 23, 2014 06:29 AM
