help with my o2 sensor cel code 41
Old Sep 6, 2007 | 09:13 AM
busyychild's Avatar
Default help with my o2 sensor cel code 41
I am pulling a cel code 41 which is the "Heated Oxygen Sensor (HO2S) Heater".
I'm trying to figure out if its the sensor or the wiring without the use of a digi multimeter (i don't have one)
When i pull the o2 sensor connector from the main harness should I also receive a code 1 (Heated Oxygen Sensor (HO2S))?
Old Sep 6, 2007 | 09:18 AM
guessman's Avatar
sounds like you need to replace O2 sensor
Old Sep 6, 2007 | 09:20 AM
busyychild's Avatar
Default Re: help with my o2 sensor cel code 41 (busyychild)
thats what i am thinking, thing is the cel came about after i had a clutch put in. acutally right when i took the car from the mechanic. i would have left it there to have him diagnose it/fix it if it was his fault but i needed the car that day.
Old Sep 6, 2007 | 09:57 AM
guessman's Avatar
did they take your car for a test drive after they fixed it? could have happened then. just thinking.
Old Sep 6, 2007 | 10:22 AM
busyychild's Avatar
Default Re: (guessman)
it was taken for a test drive after. i was the one that noticed it when i hopped in it to drive it home. it is very likely that it gave out when i turned it, but its also likely that they pinched a wire or something when connecting everything back to the main harness.
Old Sep 6, 2007 | 10:27 AM
guessman's Avatar
when you say main harness, do you mean, in the engine or under the dash? I'm just trying to get a picture of what they could have done. If it's in the engine bay, you should be able to see if it's a pinched wire. Have you taken the sensor out yet to see if it's blown? I had a sensor go bad before and it looked like the tip of the sensor mushroomed out. it's supposed to look like the tip of a nipple.
Old Sep 6, 2007 | 01:14 PM
busyychild's Avatar
havent had a chance to take the sensor out and look at it, ill try to do it this weekend, i was speaking of the main harness connection under the hood. im getting my hands on a mutimeter tomorrow.
I wanted to know if the connector was unplugged would it throw codes 1 and 41, or just 41.
Modified by busyychild at 4:30 PM 9/6/2007
924drb20
Dec 14, 2010 10:36 AM
iperez
Nov 22, 2004 10:03 AM
nwarp
Jul 17, 2004 06:01 PM
freakin_eLRoD
10
May 2, 2004 09:12 AM
