Buddyclub spec 6 cam Vs Buddyclub spec 5 cam
Old Sep 6, 2007 | 06:25 AM
redsventeen's Avatar
Default Buddyclub spec 6 cam Vs Buddyclub spec 5 cam
Anybody has tried out the Buddyclub spec 6 cams. How's the power delivery compared to the spec 5. I ran a spec 5 in my EK9 race car and it has nice smooth power delivery all the way to 9000rpm. The spec 6 has a longer duration but a lower lift. How does this affects power delivery. Thanks!
Old Sep 6, 2007 | 06:41 AM
Teamdiesel's Avatar
I didn't even know they had a spec 6. How much compression were you running with th espec 5's?
Old Sep 6, 2007 | 07:42 AM
skata89's Avatar
9k.. thats all you rev up too?
Old Sep 6, 2007 | 08:37 AM
satitus's Avatar
Default Re: Buddyclub spec 6 cam Vs Buddyclub spec 5 cam (redsventeen)
From the BC website
RACING SPEC VI EXTREME CAMSHAFTS
1.Must use buddy club valve spring
2.Must use buddy club cam gear
3.Compression must be 12.5 or over
4.Can use standard valve or oversize valve
5.Smooth idle
6.Good torque
7.No valve clearance noise
8.Easy computer mapping and setting
9.Good re-acceleration response ( will not have knocking problem as
other brand large angle cam shaft )
10.Awesome performance and power
SPEC VI
*SPEC ABSO-
LUTE ( B SERIES CAMSHIFT )
TIMING DURATION VALVE LIFT VALVE CLEARANCE
1mm OPEN 1mm OPEN
INLET 23° BTDC 50° ABDC 319° 11.8mm 0.007
1mm OPEN 1mm OPEN
EXHAUST 49° BBDC 14° ATDC 307° 11.85mm 0.008
Old Sep 6, 2007 | 02:55 PM
Dyno Dave's Avatar
I have tested 3+ & IV & V but not VI yet going by my testing you will need 13+ to 1 compression very good flowing head and a 2lt engine with good boltons to support these cams.
Regards Dyno Dave
Old Sep 6, 2007 | 03:33 PM
ipodhustle's Avatar
Default Re: Buddyclub spec 6 cam Vs Buddyclub spec 5 cam (Dyno Dave)
trust me wait a couple of months for the buddyclub spec 7+.
it's gonna be unreal.
Old Sep 6, 2007 | 03:54 PM
I'm running a 13.5 compression ratio B20B, fully ported head, crower valve, toda valve spring, wiseco 85mm piston, eagle titanium 5.394 rod, balanced crankshaft
Old Sep 6, 2007 | 06:46 PM
cartune network's Avatar
i hope u dont plan on streeting this motor but i have a buddy that is using the bc6's in his bored and stroked gsr and hes pullin 10.6 in a hatch. the bc6's are harsh i hope u have some thing that will correct the idle because ur not gonna idle its gonna bounce between 1000 and 2300 lol. his setup is 85mm pistons 95mm stroke with 14:1 comp ratio he makes serious power with them.
Old Sep 6, 2007 | 11:46 PM
UncleD's Avatar
Default Re: Buddyclub spec 6 cam Vs Buddyclub spec 5 cam (satitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satitus &raquo;</TD></TR><TR><TD CLASS="quote">
God I hope not...
Old Sep 7, 2007 | 12:05 AM
Chris Tune's Avatar
Default Re: Buddyclub spec 6 cam Vs Buddyclub spec 5 cam (clean rice)
in reality is not so hotness... in regular engines... 1.8 liters etc well i think the cam was quite large. it was comparable to a pro1... maybe a pro2, but the engine never had pro2's so i cant say. Maybe it was just a bad cam for a 1.8, maybe it wasn't even the cams they where claimed, since i didn't bought them. If i have time to find them i'll post the dyno graphs, if i can find them.
BigAl
May 12, 2006 04:06 PM
JFG Kevin
May 8, 2006 07:35 PM
5-lugHatch
Jan 30, 2005 04:58 PM
JerseySiPOS
Mar 9, 2004 08:59 PM
