Strut bars created equal?
As far as rear and front, both upper and lower. Are they all created equal? would a megan be similar to a skunk2 or tein. I searched, but just found a lot of FS's. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4EN[sic »</TD></TR><TR><TD CLASS="quote">]Personally, I think the ones that are one solid piece, welded and not bolted together are more solid and stiffen the chassis better.</TD></TR></TABLE>
yep, most things that are welded solid compared to pieced with bolts will def be stiffer. I wouldn't spend any more than $20 per bar...ebay specials get my vote. Why? strut bars stiffen the chassis but not enough to spend $100-$300 on a bar. Its all a bling factor, just my opinion.
all the ones i have found on ebay (referring to front strut bars) are bolted together, I was thinking about this
http://cgi.ebay.com/ebaymotors...85045
or this
http://cgi.ebay.com/ebaymotors...ZWDVW
I know they are exactly the same thing, but that's what I was looking at
or this
Basically to preload the bar you install them with the vehicle raised to relieve the shocktowers of weight and balance the load and if the bar is adjustable to adjust it then...taken from tanabe-usa website under strut bars.
from the two items i have listed above, which one will help my handling more? How well are the cheaper items going to fit? should i just pony up and spend some money?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Strut bars that need to be preloaded to be put on will give alot more handling then a non preload bar. </TD></TR></TABLE>
the bars that have adjustments on them. they are just as "siff" and able to preload.
Dont spend much on bars. like bmoua said, ebay it. The funtion of a strut bar is to keep the two strut towers the same distance apart. "body roll" is the term for when your chassie flex / twists and those 4 point change distances.
so a cheap ebay strut would line up well? which would help my suspension more?
or
or
Gawd dang... HT is full of ignorant-savant
Body roll is caused by the weight of the car rolling from a corner to the next, not because of chasis flex.
You could have the stiffest body ever, but if the springs and dampers are not controlled, you will still have enormous amount of body roll.
Unless you track your car with some really grippy rubber, I doubt one would see the difference between a 20$ or a 200$ bar.
BODY ROLL :
Definition; The leaning or tipping of a vehicle's body to one side when turning sharply. This reduces traction and increases tire scuff due to undesirable alignment changes. Body roll is controlled primarily by a sway bar, but the stiffness of the springs and shocks also play a role.
BODY ROLL :
not far off, relax turbo.
Edit: defintion of body roll, "The changing of the chassis' angle in relation to the ground when going through turns or corners"
Modified by THC07 at 10:22 AM 9/6/2007
You basically claimed you knew when you have no clue.
I hope your not like that at work... I hate people like you.
When you dont know, you shut up.
You call that close enough... I hope you dont try that line on your GF.
''Belly button... bah close enough''
there gonna be the same. luserkid made the point that some of them you can put a load on it. Either way you will get the same results. Go for looks. I used a stock GSR bar in the front and a cheap ebay one in back. If your car is a track car. Load-able bars IMO.
Being a front wheel drive, i would assume that the H brace would do more then the rear lower tie bar. ive read some posts about the rear lower rear bar. some ppl say not to use them. try searching a bit. with the H brace i noticed that my wheel hop was less. but I had to remove it for exhaust room. its also nice to have that H brace down there to protect the exhaust. over speed bumps n ****. I was happy i had one, on a few ocassions.
rather than spending over $100 on an aftermarket bar or going with a cheaper ebay bar, why dont you just buy an si strut bar? they are the same thing as the ctr bar and i got mine for ~$20 shipped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatty6042 »</TD></TR><TR><TD CLASS="quote">do not buy the h brace i had 1 on my integra and the bolts pulled right through the front and started making a horible noise.</TD></TR></TABLE>
i talked to a guy who has the h-brace, he says it made a good difference. He was using a NRG h-brace, not a ebay special h-brace. I'll be getting a nrg h-brace soon.
