Middle break light is out.
My middle breaklight in the rear window hasnt work since I've gotten the car. I want to try changing the bulb, but for the life of me, cant firgure out how to get the bulb socket out.
Can anyone tell me?
Can anyone tell me?
ok the middle brake light is the 3rd brake light to change the bulb you need to go into the trunk on the top just under it you will see a socket....twist it off and the bulb is inside
Alright, the bulb looks fine. Nothing broken inside. Could it be a fuse? If so, how do I find out & replace the fuse?
Or what are some other things that could be wrong with it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpot90 »</TD></TR><TR><TD CLASS="quote">Alright, the bulb looks fine. Nothing broken inside. Could it be a fuse? If so, how do I find out & replace the fuse?
Or what are some other things that could be wrong with it?</TD></TR></TABLE>
did you really try changing the bulb? also try looking at the fuse under the hood maybe or even under the driver panel
Since your car is a 6th gen, check all fuse box. There is one on each side near the front doors and there is 1 under the hood.
Is your bulb actually good? I would cross reference with your reverse light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Kid »</TD></TR><TR><TD CLASS="quote">Since your car is a 6th gen, check all fuse box. There is one on each side near the front doors and there is 1 under the hood.
Is your bulb actually good? I would cross reference with your reverse light. </TD></TR></TABLE>
Will do. Only one thing..I have no clue what to check for when it comes to fuses and whatnot. What does a "blown fuse" look like? And are they hard to replace?
I'll try switching out the reverse lights..im assuming they take the same bulb?
b18c1vtecdc2
Sep 2, 2013 09:31 PM
