MPFI, what size wire?
Old Sep 5, 2007 | 08:57 PM
Red_ED8's Avatar
Default MPFI, what size wire?
I'm getting ready to do my MPFI swap and use just woundering what gauge wire should I get to extend the TPS and wires to the injectors? I know it's not really going to make a diff but just want to be sure. 12,14,16?
Old Sep 5, 2007 | 09:09 PM
Crx dude's Avatar
Default Re: MPFI, what size wire? (Red_ED8)
20-22 gauge wiring would about it. basically just use common sense when choosing wiring
Old Sep 6, 2007 | 05:35 AM
JustAnotherRex's Avatar
I'd go 18 gauge. Avoid 12 - 14 like the plague. I used 16 gauge, but I'm still throwing a random *** code after rewiring the thing twice, checking the distributor timing, etc.
Old Sep 6, 2007 | 08:45 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
use the same gauge that the wires are. i believe there 16-18 gauge for those? maybe 20.
Old Sep 6, 2007 | 11:04 AM
low91rex's Avatar
Default Re: (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">I'd go 18 gauge. Avoid 12 - 14 like the plague. I used 16 gauge, but I'm still throwing a random *** code after rewiring the thing twice, checking the distributor timing, etc.</TD></TR></TABLE>
what code are you getting?
Old Sep 6, 2007 | 03:44 PM
Red_ED8's Avatar
Default Re: MPFI, what size wire? (The Hooligan)
Well thanks for the info, I also check the wire size on the harness.
Old Sep 6, 2007 | 04:35 PM
Default Re: (low91rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low91rex &raquo;</TD></TR><TR><TD CLASS="quote">
what code are you getting?</TD></TR></TABLE>
9. Timing on distributor and belt is 100%. I've rerun the wires, I've rerun the pins, and I've soldered everything.
Dekorum
Jun 23, 2010 09:03 PM
iinvazionii
Audio / Security / Video
Apr 11, 2007 08:56 PM
Voodooboy520
Dec 3, 2005 03:59 PM
noob with an RS
Dec 27, 2004 09:30 AM
