Can I swap tranny's?????
Old Jun 15, 2002 | 03:03 PM
Wo-Nelly's Avatar
Default Can I swap tranny's?????
I got a 2k prelude sh and I was wondering if I can swap to another tranny? Apperantly the 5th gen prelude tranny's can't take as much abuse or power. I was thinking of a Accord or even 4th gen prelude tranny. Does either one or any other one bolt right up?
Old Jun 15, 2002 | 04:20 PM
mattmw88's Avatar
Default Re: Can I swap tranny's????? (GottaLude)
hhhmmm... I know that with the h22a the trans from the f22a fit good. Since it's basically the same engine, but w/ obdII, I'd think that a 4th gen tranny would bolt up just fine. Can someone back me up?
Old Jun 15, 2002 | 05:09 PM
Wo-Nelly's Avatar
Default Re: Can I swap tranny's????? (mattmw88)
Well I figure since the accords 90-01 and 97-99 acura cl's and the 97+ preludes share the same clutch kits it's gotta have some similarities.
Old Jun 15, 2002 | 07:14 PM
fastludeh22's Avatar
ya, but u dont want an f-series one because of the crappy gear ratios, trust me! i've heard some things about the sh being different, but i dont know. if its the same get the m2b4 jdm lsd from the 4th gen lude, plus it has the best ratios
Old Jun 16, 2002 | 02:50 PM
Wo-Nelly's Avatar
Default Re: Can I swap tranny's????? (93ludevtec)
Whats wrong with the gear ratios? I don't think I would mind longer gear ratios, to me that just means a longer time in boost.
Old Jun 16, 2002 | 04:47 PM
Quaalude's Avatar
i think with the sh block you can only use a sh tranny....the base block you can use the other trannies
Old Jun 16, 2002 | 05:59 PM
Wo-Nelly's Avatar
Default Re: Can I swap tranny's????? (Quaalude)
what kinda mods and how difficult will it be to fit the other tranny's onto the sh block?
Old Jun 16, 2002 | 11:44 PM
akkording's Avatar
New User
I have a SH tranny for sell if you want a spare one.
Old Jun 17, 2002 | 06:33 AM
kevie88's Avatar
Default Re: Can I swap tranny's????? (akkording)
That isn't true, You can bolt any H series tranny to any H series motor.
Old Jun 17, 2002 | 07:17 AM
aklucsarits's Avatar
New User
The 5th gen tranny is, for all intents, identical to the 4th gen tranny other than gear ratios. I don't think you would want to swap the original tranny from your 2000 model year car to a used tranny that is 6 to 10 years old and likely has considerably more milage on it...
The point is moot anyway because the Type SH cannot accept a Base model tranny (4th or 5th gen). The reason it won't work is because the input shaft length is different on the Type SH.
Andrew
Old Jun 18, 2002 | 09:15 AM
i guess its all a matter of opion. i hate my f-series, but im not boosted, unless u count n2o. but i think shorter gears=more accel=better times, but ill let you know im going back to my lsd one
Old Jun 18, 2002 | 09:30 AM
H22Si's Avatar
The 4th Gen Prelude trannies are geared more towards acceleration while the 5th Gen trannies are spaced out slightly more. 5Th Gen owners would see an increase in performance if using the 4th Gen tranny.
I wouldn't reccomend using an accord transmission unless you have FI planned because of the outrageously spaced gears and small final drive.
After playing around with the gear ratios from the Accord and 4th Gen Prelude, i've noticed that on an H22 platform using the Accord tranny, the Accords 3rd gear would produce the same pulling power as the Preludes 4th gear. Est. 180mph top speed if you could pull to redline with the Accord Tranny.
Old Jun 18, 2002 | 10:13 AM
Wo-Nelly's Avatar
Default Re: Can I swap tranny's????? (aklucsarits)
Well I am turbo charged already makeing 245whp@6psi... I'm asking cause now that I figured that you can't add a lsd on the type sh tranny I think I'm going to buy a base block, find a accord tranny and add a lsd to it. I think I rather keep my sh tranny and add a lsd but apperantly I can't.
Old Jun 18, 2002 | 11:29 AM
where are you located at? if your in ga, i have my block/tranny pulled out of my 4th gen right now (god she's going to be bad!!!!, FULL rebuild), if you pulled your tranny, you could come over and compare it to see if it would bolt up. also my long geared/low miles one is for sale, i think its sold but he might flame, you know how that goes...but i still say get a jdm lsd vtec tranny...let me know
Jo3siah
Jan 8, 2014 05:36 PM
BB4-Japanpower
Mar 6, 2006 08:01 AM
aus_newbie
Sep 1, 2005 04:34 AM
edulerp97
Jul 3, 2005 06:19 AM
Hondadrvr215
Sep 28, 2004 08:55 PM
