turbo zc owners...
hey whats up
i just sold my car and i am buying a 91 si hatch... i was thinkingn bout doing a ZC turbo...can you use the greddy sohc vtec kit? and kinda have to make the IC pipes work...?? how much boost can you run on that motor? and what kinda times are you running with this setup? last question how much are they turbo kits going for?
thanks mike
thanks mike
Guest
Posts: n/a
hey whats up
thanks mike
thanks mike
dunno is greddy kit will work call and ask. drags for the ef si will prolly work best
amount of bost depends on condition of motor and whats been done to it
times will varry
turbo kits = 3grand
the greddy kit will work. you just gotta trim a lil' bit off the manifold to keep it from hitting the block. the intercooler pipes are easy to make,essentially they run the same route as a CAI. i cut my own and had 'em welded for 40 bucks.
if bulit up right ZC's can handle a decent amount of boost.
here are a few sites that give you some good info-
http://www.gamesbbs.com/~dmoore/
http://www.homemadeturbo.com
CRXMATT
May 29, 2002 11:48 AM
