tach install help please
i searched alot of different combinations and cant find anything, i bought a raptor shift light and know where to hook power and ground but i dont know where to run the tach wire to.
its a 1989 crx si obd0 with a zc and it says i should run it off the ecu, it says i should not hook it straight to the coil as it wont read right.
can anyone tell me what color the tach wire of the ecu is or can i use a splice connecter on the negative wire off the distributor?
any help would be greatly appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmd15bciviconrice »</TD></TR><TR><TD CLASS="quote">Blue wire</TD></TR></TABLE>
is there only one blue wire off the ecu?
not off the ecu its behind the gauge cluster and that one i believe runs off the dizzy not sure but thats the one i used for my d15b but it might not work due to the fact you have a zc
