cam tech
Old Jun 15, 2002 | 02:28 PM
86CRXSi's Avatar
Default cam tech
looking for web site to learn bout cams and hoe they work to help pick my next cam..................note: have sohc........thanks.
Old Jun 15, 2002 | 03:17 PM
Urban Business
Guest
Posts: n/a
Default Re: cam tech (86CRXSi)
cams are quite simple. they have lobes (protrusions) off the cilindar. the cam is attached to a cam gear which is either belt or chain driven off the pully (which is attached to the crank) when the pully spins the belt or chain turns the cam gear which turns the cam. each lobe will push into the lifter or rocker arm which is attacked to the valves. inturn the valves move up and down. the longer the duration (larger the lobe) the better, usually. this allows for more complete combustion as well as release of exhaust gasses via the valves. valves are spring loaded so that when the lobe pushes them down into the head they dont stay down. hope this helps
Old Jun 15, 2002 | 03:23 PM
poison's Avatar
Default Re: cam tech (TorteX)
well explained, but no good enough
http://www.howstuffworks.com/camshaft.htm
'nuff said.
Old Jun 15, 2002 | 03:26 PM
Urban Business
Guest
Posts: n/a
Default Re: cam tech (poison)
/me shrugs
sweet and simple
Old Jun 15, 2002 | 03:29 PM
Urban Business
Guest
Posts: n/a
thats a good site tho... hehe look at how ghey the pushrods are
Old Jun 15, 2002 | 04:02 PM
poison's Avatar
haha, true. explains it good though
Old Jun 15, 2002 | 08:04 PM
Jockobo's Avatar
http://www.cranecams.com
theyre the ****....i made 120 at the wheels with them on a 1.5
mouab18c1
15
May 6, 2011 11:22 PM
91redteg
10
Oct 16, 2007 09:38 AM
superstock2
Sep 10, 2006 05:56 AM
xDicktonesx
13
Feb 21, 2006 12:51 PM
GSRBoi785
May 22, 2004 08:31 AM
