Questions Vs 1992 Lude si H2.3
first question. for some reason my passenger door dosnt like to open from the outside and occasionally from the inside as-well. it will open 80% of the time on the inside and 20% on the outside. its driving me nutz any idea's on that.
second rarely very rarely my car will not start. the starter is enguageing and the engine is turning but no start. if i w8 5 min after this it will start fine and be fine again for a few days till it does the same thing again.
the not starting problem is most likely the main relay. its under the dash of the driver side kinda anoying to get to. if the car wont start try waiting till the second beep when you turn the key before starting the car. then right when u hear that second beep start the ignition. it should start up. my right door also has same problem it gets alot of air pressure i guess since it doesnt get opened alot.. just give it a good pull and it should open. (unless your talking about the locking system)
thanks for the help with the starting im going to try that in the daylight (east coast )
the door on the other hand well idk its not from aid seems theres just a fault and idk what yet
EFEvedell
11
Dec 1, 2011 09:47 AM
nObOdy65
Oct 13, 2005 08:14 AM
