40MPH Hum
Old Sep 5, 2007 | 03:43 PM
HondaAccordTdR's Avatar
Default 40MPH Hum
Today i started hearing this weird "hum noise" that i can hear really loudly after 40MPH. I took off the plastic fairing over the wheel, think it could be this. but the noise is still there. Do brake pads rub when brand new?
Old Sep 5, 2007 | 04:21 PM
rdblckSV650S's Avatar
Default Re: 40MPH Hum (HondaAccordTdR)
it was my understanding that brake pads rub all the time.
Old Sep 5, 2007 | 04:26 PM
Default Re: 40MPH Hum (rdblckSV650S)
Walked right into that one...
Old Sep 5, 2007 | 04:30 PM
Quiks66's Avatar
Could it be a wheel bearing? Either way you'd want to get that checked out before too long. You only have 2 good wheels...
Old Sep 5, 2007 | 04:40 PM
Default Re: 40MPH Hum (Quiks66)
Well after a short ride to try and find out where it is coming from, i noticed that with barely using the brakes, the front right disc is hot to the touch where as the left disc is just warm. My guess is the pad is rubbing like crazy, going to take it off and have a looksy.
Old Sep 5, 2007 | 04:55 PM
EDIT... Didnt think of normal breake in for the brakes... Thanks for the help.
Old Sep 6, 2007 | 05:42 AM
newby_j's Avatar
Needs More Cowbell
stuck caliper?
Old Sep 6, 2007 | 05:43 AM
MSchu's Avatar
My Name is Nobody
It's called "bedding in"... I wouldn't call a brake noise a hum though, is it coming from the front or rear? the reason I ask is if it sounds like it is coming from under you your chain may be overly tight. this si a bad thing.
Modified by MSchu at 7:06 AM 9/6/2007
Old Sep 6, 2007 | 01:12 PM
Default Re: 40MPH Hum (MSchu)
Sounds like its coming from the front. Ill check my chain though, i recently tightened it up.
Old Sep 6, 2007 | 02:45 PM
Well i loosened the chain, and im still getting the sound. Even when im in neutral/engaging the clutch the sound is still there. I hope its just the brakes, i just passed 100 miles on the new pads.
Old Sep 6, 2007 | 03:43 PM
MSchu's Avatar
My Name is Nobody
A chain that is to tight will still hum even when drive is not engaged... you sure the chain is tensioned correctly? The hum could be tire wear or tread pattern/road harmonics. If your brakes are really dragging enough to hum, there should be visible smoking at times from over use and materials heated beyond specifications.
JayBinNyC88
Honda Civic (2006 - 2015)
Jul 24, 2007 09:33 AM
pcguy760
Apr 8, 2007 03:52 PM
superburner2
Mar 28, 2005 05:05 AM
FortunateFool.
May 21, 2004 06:09 PM
RolioPolio
Jun 29, 2002 01:38 AM
