d15b hydro tranny
do you have a hydro set up or not cause if you dont its going to be alot more work but all you have to do is make sure the clutch disk has the same amount of splines as the tranny the jdm d15b tranny bolts right up to the usdm d15b-- except for the tranny mounts you will need a z6(i think thats what i used) mount for the jdm version. but yes you can use it.
LorenGeist
Aug 13, 2004 11:05 AM
