noob build question!! help grealty appreciated!!
Old Sep 5, 2007 | 03:02 PM
hndacord02's Avatar
Default noob build question!! help grealty appreciated!!
hey guys, its that time, and we are pulling out the b16a2 and swapping in a b18c in its place. I got a couple noob questions. first, heres the setup: this car is to be a dd...
intake, full exhaust, header, intake mani, throttle body.
Skunk2 valves, retainers, springs, and proseries stage 2 cams.
looking at the possibility of swapping in pistons as well.
Q's:
What size throttle body would be best for this motor? 70 or 68mm?
What pistons will give higher comp. and be good overall?
thanks for the help!
Modified by hndacord02 at 7:16 PM 9/5/2007
Old Sep 5, 2007 | 06:28 PM
hndacord02's Avatar
Default Re: noob build question!! help grealty appreciated!! (hndacord02)
bumpers
Old Sep 6, 2007 | 03:55 PM
hndacord02's Avatar
anybody?
Old Sep 6, 2007 | 04:31 PM
itgsr98's Avatar
If you plan on keeping the bottom end stock pro2's are over kill. BCIII's (if stock)pro1's if your upping the compression. I wouldn't go bigger than that.
Some suggetions to keep it reliable and in the 190-200whp range.
Good long tube header(not ebay)
US type r or jdm type r pistons(jdm have slightly more compression)
64-65mm throttle body
3"cold air with velocity stack.(good over all power adder)
Old Sep 6, 2007 | 08:18 PM
hndacord02's Avatar
Default Re: noob build question!! help grealty appreciated!! (itgsr98)
ok, any good header in particular, the b16 header obviously wont fit, so how would the dc work for it? thanks! ho ya, and what is the jdm gsr tb size stock?
marshall12395
21
Nov 17, 2012 06:11 PM
snowblind7x
Mar 29, 2011 09:53 PM
PreStaged12s
19
Sep 23, 2009 12:10 AM
respectblades
Jun 22, 2003 04:08 PM
Vspec Sol
Apr 4, 2003 02:16 PM
