Smallest front sway bar for a EK?
Old Sep 5, 2007 | 02:07 PM
ekim952522000's Avatar
Default Smallest front sway bar for a EK?
What is the smallest front sway bar that is avaible for a EK (OEM or aftermarket)?
Old Sep 5, 2007 | 02:14 PM
bmoua's Avatar
look for the sway bar off the 96-00 civic hx...i know the 96-00 civic ex came with the 22mm front sway.
Why are you asking for??
Old Sep 5, 2007 | 05:02 PM
Default Re: (bmoua)
Because I don't want to run without out one but I am looking for a smaller I have a ex 22mm is there any that are smaller?
Old Sep 5, 2007 | 05:08 PM
excivicboy96's Avatar
Default Re: (ekim952522000)
Does anyone know if its possible to run 92-95 civic bars? I found that the 92-95 civic VX has a 19mm sway bar in the front.
Old Sep 5, 2007 | 08:50 PM
Default Re: (excivicboy96)
19mm would be cool.
Old Sep 5, 2007 | 09:23 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">Because I don't want to run without out one but I am looking for a smaller I have a ex 22mm is there any that are smaller?</TD></TR></TABLE>
are you trying to use a front sway but exclude the need for hx/ex LCA's?? thats the only reason i can think of for the downgrade.
Old Sep 5, 2007 | 09:58 PM
RiceKillinSI's Avatar
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">
are you trying to use a front sway but exclude the need for hx/ex LCA's?? thats the only reason i can think of for the downgrade. </TD></TR></TABLE>
Less weight on a drag car maybe???
Old Sep 5, 2007 | 10:12 PM
bmoua's Avatar
Default Re: (RiceKillinSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceKillinSI &raquo;</TD></TR><TR><TD CLASS="quote">
Less weight on a drag car maybe???</TD></TR></TABLE>
i've seen drag guys completely take off there front sways.
Old Sep 5, 2007 | 10:20 PM
Default Re: (bmoua)
Yes. You really don't need a sway bar if you only drive in a straight line. but maybe he drives his on the street occasionally. He would need at least a small sway bar to keep it driveable.
Old Sep 6, 2007 | 01:25 AM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if its possible to run 92-95 civic bars? I found that the 92-95 civic VX has a 19mm sway bar in the front.</TD></TR></TABLE>
My VX, as well as other VXs from the factory, did not come with a front sway bar.
92-95 Civic Si/EX/LX came with 21mm bars, which will fit.
Old Sep 6, 2007 | 01:27 AM
bmoua's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i thought too bro haha...i knew the vx/dx/cx didn't come with front sways.
Old Sep 6, 2007 | 04:27 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (bmoua)
I don't see why you're so worried about getting the smallest one. Get A sway bar and work from there.
If you're worried about the front one being too big, just get a rear sway bar anyway to compensate. You'll really enjoy how the car drives.
Old Sep 6, 2007 | 11:53 AM
Default Re: (ek forever guy)
I have 2 other sway bars this is for my hondachallenge car I would like to have diffrent sizes to test.
I have a 25mm a 22mm and would love to have a 19mm to test I will also be testing no front sway bar.
So does anyone know if the 19mm fits?
Old Sep 6, 2007 | 11:56 AM
B18CivicEJ8's Avatar
If you are looking to decrease understeer, why don't you just add on the rear sway from the 99-00 Si?
Eran's Avatar
HT White Ops
Default Re: (B18CivicEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">If you are looking to decrease understeer, why don't you just add on the rear sway from the 99-00 Si?</TD></TR></TABLE>
Because it's a 13mm bar and it's tiny ... he wants a small FRONT bar.
Old Sep 6, 2007 | 12:02 PM
Relic1's Avatar
there was an 18mm made for some JDM cars, but nothing that I can track down at the moment.
unless you're running a tight parkinglot track the 24 or 21 will be your best bet.
note:
EK SI = 26mm
ITR & a lot of tegs = 24mm
Old Sep 8, 2007 | 05:53 PM
Default Re: (Relic1)
Ok so I found out that 92-95 civic VX's have a 19mm front sway bar.
So my next question is will a 92-95 civic VX front sway bar work on a 97 civic?
http://www.hondaautomotivepart...R+ARM
https://honda-tech.com/zerothread?id=2007473
Old Sep 9, 2007 | 10:31 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I found out that 92-95 civic VX's have a 19mm front sway bar.</TD></TR></TABLE>
the VX never came with a front sway bar.
I own a 92 and work on a 94 & 95 for friends. not a one of them had a front or rear sway bar.
the honda parts list also confirms this.
jrunager
Suspension & Brakes
23
Oct 24, 2012 10:30 AM
siblues
Mar 21, 2008 02:35 PM
shotgun2224
Suspension & Brakes
Feb 4, 2008 05:02 PM
JLEK
11
Jun 11, 2007 08:50 AM
GAME OVER 2007
Oct 13, 2005 03:01 PM
