f20b stroker
Old Sep 5, 2007 | 02:03 PM
sean-sports's Avatar
Default f20b stroker
i have a f20b motor i want to make it in to a stroker motor i heard you can use the f23 carnk and rods and use h22 pistons but they will pop out a little and i heard if you use f20c pistons s2000 they fit perfect is this true all threads i have search it tells you about the h23 block not a f20b any info would help and would a h23 with a h22 head swap be better
Modified by sean-sports at 3:16 PM 9/5/2007
Old Sep 5, 2007 | 04:05 PM
machine4321's Avatar
well the problem lies with the f20b being 85mm bore .
deck heigth is the same on all the h and f blocks.
youd have to sleeve and bore the f20 to 87mm to make the h22 or anyothe h piston
the f20 block is the dame as the f23 and h22a4 from 98+
Old Sep 5, 2007 | 04:26 PM
CeReal's Avatar
Default Re: (machine4321)
http://www.raceseek.com/honda_specs.htm
Old Sep 5, 2007 | 04:30 PM
Professor15's Avatar
if im not mistaken the f20b doesnt have the Frm sleeves like the H's do. so get a longer stroke and run custom forged internals. Might be more expensive then running h-series rods, and notching the pistons or some ****. but will be safer if done correctly.
HksHaitian
Sep 15, 2013 01:09 PM
misterpsycho
Jan 11, 2008 04:20 AM
boostedh22lude1
Oct 16, 2007 01:22 PM
brycemartin
Nov 27, 2005 05:42 PM
JDM_COUPE
May 7, 2005 09:10 PM
