JDM rear crossmember vs USDM rear crossmember ???
Car: 88 Crx Si
I was wondering could I swap the US rear crossmember out for a JDM one?
Would it make a difference because the car is rhd? Would the rear mount bracket be different if I get a SiR crossmember?
{now back the to USDM one}
Would a 88-91 Civic hb (or sedan) have the same rear crossmember as the rex? I want to think yes, but you know how honda does with minor differences.
Before you jump the gun and ask why, I believe mines is bent and I can get a Japanese one for cheap ($75), buy a new one from honda ($300+), or luck up and find a rex at a local junkyard (slim odds) then I got to pull it myself which I dont have the time for.
Thanks for you help.
I just did some searching on how to replace the rear crossmember, and someone posted that they (jdm/usdm) are the same, but the steering components (which I dont need) are different.
Do people swap that crossmember when doing a rhd conversion?
see where i circled? that is part of the steering rake and it has a hole in the cross member that it goes thru and it doesnt have it on the left hand side.
aziantegger10
Apr 19, 2005 06:14 PM
posterchild
30
Jun 20, 2004 10:44 AM
AzN_Flava
Jan 29, 2003 02:55 AM
Type R 98-0352
May 2, 2002 08:43 PM
