Air conditioning? To much pressure leaking fron back of compressor.
Old Sep 5, 2007 | 11:11 AM
1 Fly SI's Avatar
Default Air conditioning? To much pressure leaking fron back of compressor.
So after 3 years of perfect ac the damn thing just quit. So I took it up to my buddies shop and replaced the valve stem seals, Vacumed the system and charged it. It worked great for 1 night. Next day it was hot again. I added die this time and recharged. Gone next day again.
I found the leak on the back of the compressor. I don't know what valve it is but my friend said it is to release pressure. (valve is #3 on pic)
http://www.hondaautomotivepart...EN%29
Can it get stuck open or something.
I just bought a new drier and expansion valve and need to know if I should replace the valve on the back of the compresser or not.
Old Sep 5, 2007 | 11:38 AM
Trakhor's Avatar
Torque Junkie
Default Re: Air conditioning? To much pressure leaking fron back of compressor. (1 Fly SI)
This is the "mysterious" pop off valve. I know of about 12 of these little PITAs that have gone out. I don't know at what point these blow but once they go you have to replace them. One of my buddies jbwelded his....I don't know if that is a safe solution.
As moraly wrong as some may think this is I stole one from my Mustang that's getting tore down for roadcourse only duty. It's the same thread but I'm sure it's calibrated for a different psi...the a/c in the Mustang was icy cold before I started tearing it apart....
Advance auto parts seems to list these, but oddly enough they quore a sae thread...
I've replaced the expansion valve in mine hoping that the obstruction that would have caused the pressure to go high enough to blow the pop off vavle was in there as the expansion valve and the compressor are the only moving parts.
Jason
Old Sep 5, 2007 | 03:58 PM
1 Fly SI's Avatar
Default Re: Air conditioning? To much pressure leaking fron back of compressor. (Trakhor)
Change the pop off valve or not?
Old Sep 5, 2007 | 05:09 PM
Trakhor's Avatar
Torque Junkie
At this point I have to recommend changing the pop off valve and the expansion valve. I may change my opinion once i charge my system again.
Jason
Old Sep 6, 2007 | 05:35 PM
1 Fly SI's Avatar
Well I installed a new pop off valve,expansion valve and a drier. Charged the systen and the damn pop off is still leaking. Is there any way to diagnose the problem?
maxboost10
13
Jul 26, 2022 02:22 AM
cmq1173
Honda Civic (2006 - 2015)
Apr 7, 2010 04:56 PM
slickrc
Apr 26, 2006 06:59 PM
civic_dork
Aug 21, 2005 10:50 AM
zcivic91
11
Jul 30, 2002 08:27 AM
