Brake lines for my hatch
Has anyone ever replaced the brake lines (steel) that come from the M/C to the back of the rear brakes? My lines rotted and the M/C isn't holding any fluid because it's leaking from the rotted area. If so how difficult was it? BTW Dealer wants more than $900 to replace this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">You could get your own lines and bend them yourself. That is a much cheaper route. </TD></TR></TABLE> Yupper, not hard to do either, first time I ever did that I didn't bust a single line and they worked great
Doing hard-lines is not difficult at all, however;
If you have never done them before, I'd recommend that you buy a bunch of cheap tubing and make up a whole bunch of "test" flares in order to learn how to do them!!
Buy a quality flare tool and bender. They are a good investment that you will continue to use over the years.
Wes
Wes
From: Where the wild things are in, NY, United States of America
The Snap-On or SK Tools flaring kits are fantastic. I recommend wire hangers to figure out where you need to go. hell, you never know, you might even end up cleaning it up a bit
drewboy
Nov 27, 2005 04:38 PM
