How the heck do i get my back seat bench out ... 5th gen accord
Old Sep 5, 2007 | 09:53 AM
sonicxtacy02's Avatar
Default How the heck do i get my back seat bench out ... 5th gen accord
I'm changing my interior from brown to black and i need to take out the back seat.. but i cant for the life of me get the hooks outta the holes.. is there an easier way of handling this that i'm just not aware of? And while i'm posting do they even MAKE seats for a 5th gen honda in black. I couldnt find front black ones so i bought 2000 prelude black seats to put in.
Old Sep 5, 2007 | 10:09 AM
oem_certified_accord's Avatar
Default Re: How the heck do i get my back seat bench out ... 5th gen accord (sonicxtacy02)
you have to be gentle with them like there were your lady. easy them out. wiggle a little bit, and pop goes the weasel.
Old Sep 5, 2007 | 10:12 AM
awdgsx96's Avatar
Just tilt towards front of the car and pull up and out. Pretty easy just try not to be to hard or they can snap from the seat if it's old enough
Old Sep 5, 2007 | 10:16 AM
Charri's Avatar
Default Re: How the heck do i get my back seat bench out ... 5th gen accord (awdgsx96)
have you tried pushing down on the back seat to pop it off the hook?
Old Sep 5, 2007 | 11:37 AM
thatasiankidtony's Avatar
There's a bolt, I think it's a size 12? But feel around the seatbeat buckles on the mid-right side. You need to stick your fingers down there to feel for it.
Look on the bottom of this post it has it: https://honda-tech.com/zero...age=1
Old Sep 5, 2007 | 12:06 PM
TheMuffinMan's Avatar
He knows where you live!
If you have a sedan, the side bolsters have a 10mm bolt at the bottom of each side, and then you push upwards on them.
The back part is held in by two 10mm or 12mm bolts on either side.
The bottom cushion on a sedan I'm not sure, the coupe (which I imagine they're similar) has a 10/12mm bolt at the back in the middle and then two hooks, one on either side.
Old Sep 6, 2007 | 08:56 AM
i'll try it out tonight... i think if i can find those bolts it'll make getting it out of the hooks alot easier. Thanks
Old Sep 6, 2007 | 10:40 AM
SuShiBoiiii's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">If you have a sedan, the side bolsters have a 10mm bolt at the bottom of each side, and then you push upwards on them.
The bottom cushion on a sedan I'm not sure, the coupe (which I imagine they're similar) has a 10/12mm bolt at the back in the middle and then two hooks, one on either side.</TD></TR></TABLE>
hes right on the money
Old Sep 10, 2007 | 03:05 PM
Default Re: (SuShiBoiiii)
got it out.. its kinda odd that the bolt is offset and not in the center of the bench.
masonb60
Nov 21, 2007 12:44 AM
ScareyH22A
Jul 20, 2006 02:58 PM
AEMPearlPrelude
May 2, 2004 09:40 AM
DrunkNRacer
Jan 8, 2004 03:18 PM
