b18c1 engine knock
Old Sep 5, 2007 | 09:44 AM
shifts's Avatar
Default b18c1 engine knock
i think its knockin. how do i tell? it only knocks at low idle. if i press the gas bringin it up to 3k it stops. ive read that if it stops then its not the rings? maybe its piston slap? nebody want to chime in? i am about to boost but dont want to slap it on only for it to blow 10 mins later. thanks!
Old Sep 5, 2007 | 10:29 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: b18c1 engine knock (shifts)
may be low oil pressure. get it to make the noise constantly, not by dropping all the oil out, but if it does it at idle, start popping off plug wires one by one. when and if the noise goes away, it will tell you (if it is a rod bearing) which one it is.
Old Sep 5, 2007 | 11:35 AM
shifts's Avatar
Default Re: b18c1 engine knock (boostedcivicsir)
thats what i was thinkin. i want to check the oil pressure. might b just that i need a new pump. its sounds like its comin from cyl 4. do i just pull the plugs at idle since thats when it makes it?
Old Sep 5, 2007 | 11:44 AM
shifts's Avatar
oh n also on start up sometimes the oil lights flickers but then goes away.
Old Sep 5, 2007 | 12:03 PM
Mr. Badwrench
if it is flickering at idle, you may have a pressure issue.
Old Sep 6, 2007 | 06:12 AM
shifts's Avatar
ne others?
Old Sep 9, 2007 | 09:46 PM
Turbo B18C EJ6's Avatar
sounds like u have a rod bearing starting to go. i would def drop the pan at least and and check starting with cyl #4 since u think its coming from that cyl. Also that would explain why your oil pressure lights coming on, resulting in a spun bearing causing a loss of oil pressure. good luck
b20ricepower
Dec 16, 2013 07:44 AM
H9Omega
May 15, 2009 04:15 PM
sik_tC
Dec 20, 2008 01:20 PM
techsx
Aug 21, 2008 12:16 PM
dublaaciv
Oct 20, 2005 09:37 PM
