Window wont go the whole way up!!!!!
Old Sep 5, 2007 | 09:24 AM
85turbottype's Avatar
Default Window wont go the whole way up!!!!!
Ok, here is my current situation. The window motor in my rear drivers side window just failed! So, I replaced it with a junk yard swap. The window now stops about 1/4 to 1/2 inch short of going up the whole way. When I was changing the motor out the window went up the whole way just fine. As soon as I bolted the window to the actuator, it now stops short. I even layed out the 2 motors next to each other to check the size and angles. I even looked at the mounting brackets to make sure they were all in the same locations. Any advice would be very appreciated!!!
Thanks a ton!!!
Old Sep 6, 2007 | 03:38 PM
Default Re: Window wont go the whole way up!!!!! (85turbottype)
bump
Old Sep 7, 2007 | 01:45 PM
Honda-Master's Avatar
it sounds like the clip at the top corner is broken , thus keeping window from going all the way up,
http://www.hondaaccordforum.co...m.htm
Old Sep 7, 2007 | 06:36 PM
Default Re: Window wont go the whole way up!!!!! (Honda-Master)
That link is excellent!!!! Thanks a ton. I cant belive that I didnt think of that!! Such a simple fix.
Old Sep 7, 2007 | 09:22 PM
gianinline's Avatar
Are you sure you installed properly????
Old Sep 9, 2007 | 02:50 PM
Default Re: (gianinline)
I would say I give it a 99.9% chance of proper install. I think the motor is just weak.
Nealva
Oct 12, 2016 11:41 AM
RBaluca.com
Aug 20, 2006 02:08 PM
BabyBadassIntegraGSR
Oct 21, 2002 03:32 AM
