s300 datalog fuel pressure. a thought.
Mr. Badwrench
this may or may not be my first tech thread. i cant remember so it probably is. i posted this in the fi forum as well, so i figured what the hell. so here goes.
i know i need an 8bar 5 volt pressure transducer,(atleast, that will give me 105psi, running 80 +- now under boost at its highest.) but can the s300's analog input be used with that to log fuel pressure? all i would need is the scaling like the wideband correct? meaning 0v= 0psi and 5v= 100psi so on and so forth. i know there is one or 2 things needed to be done to the board though.
i was having problems with my fuel system and i think i have it nailed down now, but would like to know if my pump is dropping off up top, not that it is now but would like to see if there is any decline in performance
danno33
Dec 27, 2006 02:16 PM
