h22 swap revs up and down not fitv ot iacv
Old Sep 5, 2007 | 07:38 AM
EGhatch22's Avatar
Default h22 swap revs up and down not fitv ot iacv
The car idles fine for about 4 mins then it starts reving up and down with a pop noise from the throttle body when the rpms drop. Then if i shut it off and try to start it again the car just idles up and down. I have to reset my ecu so it can idle fine but then it starts to jump again. I have no cels. Do u think it can be my ecu. Its a p28? I have a h22 in a 94 gsr....I also cleaned the fitv and iacv.
Old Sep 5, 2007 | 07:53 AM
EGhatch22's Avatar
Default Re: h22 swap revs up and down not fitv ot iacv (EGhatch22)
when i have the distributor retarted the car idles fine but when i give it gas then it starts reving up and down
Old Sep 5, 2007 | 04:13 PM
JasonST's Avatar
The pop noise is it pretty loud? Is the p28 ur using chipped/tuned? Do a compression test on ur cylinders, also check for vacuum leaks. What do u mean by having the distributor restarted?
Old Sep 5, 2007 | 05:07 PM
EGhatch22's Avatar
Default Re: h22 swap revs up and down not fitv ot iacv (JasonST)
no its not loud, it sounds like if you open the throttle body and release it. I am using a virgen p28. I have no vaccum leaks
hondaaccordf23
Sep 30, 2012 08:39 AM
chrisff521
Dec 11, 2010 06:01 AM
mtsepulveda85
Feb 13, 2008 04:38 PM
blackludeH22
Jul 9, 2004 07:09 PM
KNIVES
Apr 7, 2004 05:24 PM
