car pulling left
hey guys i have an 01 accord
the car recently started pulling left.
initially i thought it was the alignment, so i went ahaed and got it done.
the car is still pulling left....
can anyone give me a suggestion on whats going on?
also, the rear sway bar endling is broken (passenger side) but i dont believe this would cause that, would it?
thanks in advance....
could be a tire issue,, chk the tires
switch the frt tires side to side , if it pulls the other way you got a bad tire ,, if it still pulls left , rotate to rear , if it still pulls left you might have some bent suspension parts or they mis aligned the car ,,
if alignment is all in specs you might have to shift the frt beam
lsbufis
Apr 3, 2011 05:07 PM
00CIVICSITEIN
Mar 14, 2004 08:55 PM
