HELP: putting door handle latch for the key back on
Old Sep 5, 2007 | 12:04 AM
cilvia's Avatar
Default HELP: putting door handle latch for the key back on
ok i just got my car painted and before it got painted i removed the door handles and left the latches dangling...when i was putting my door handles back on, i connected the latch to the key part but the other end is dangling around and i dont know where it was supposed to connect to...can anyone help please thanks..
Old Sep 5, 2007 | 04:07 AM
RIZOBIZERT's Avatar
Default Re: HELP: putting door handle latch for the key back on (cilvia)
I'm a little confused by your description, could you post a photo. I work in autobody and take these apart all the time, be glad to help, but I'm a little confused by your description.
Old Sep 5, 2007 | 11:03 AM
cilvia's Avatar
Default Re: HELP: putting door handle latch for the key back on (RIZOBIZERT)
sure thing...
Old Sep 5, 2007 | 11:05 AM
cilvia's Avatar
so basically the other end that isnt attached to the key entry piece is what im trying to figure out what to connect to to make my key unlock and lock the doors...thanks...need help asap since i got work ina bit and wanna get it done by then haha
Old Sep 9, 2007 | 05:32 AM
RIZOBIZERT's Avatar
The key cylinder should go through the handle in the door. Their should be a large 'c' clip that retains the key cylinder in the handle. Next, two bolts hold the handle in the door with a large (about the size of the handle) metal bracket on the back side (interior of the door). The lock rod is then attached to the latch mechanism. I don't have a photo of one, but their should be 4 rods that go to the latch. One from the interior handle, one from the interior lock, one from the exterior handle and finally one from the exterior lock cylinder. The lock cylinder is going to attach to the same mechanism on the latch that the interior lock rod attaches to. I'm not sure who dismantled the vehicle, but the grommets on the end of the rods should have been left in their respective places and the grommet should have been turned and the rod popped out leaving the grommet in the original device. I'm not sure what year your car is, only the 96 and up civics have the metal retainer on the back of the handle for anti-theft purposes. Finally, to see a schematic, try Hondapartscheap.com. I hope this helps.
Prudz_lude
May 15, 2014 01:53 PM
jxhxb
Jan 31, 2008 10:14 PM
04crv20
Oct 27, 2007 05:39 PM
projectPSI
Feb 23, 2005 05:04 PM
