my new set up need some advise *texas*
on my old set up i made 300hp stoopid tuned useing a drag mani and 2.5dp
ok im wanting around 400-450
useing this set up and ross 9:3 1 pistons and eagle h beams what should i change
heres the run down on the car
gsr (will have ross pistons and eagle rods and block gaurd)
xsi b16 tranny with lsd
bbk mani and 70 mm tbody
turbonetics 57trim
tial 38mm wastegate
nice ram horn and 3inch dp
pte 880cc injectors walbro 19o pump
stock head (i have a built head on my ek its a b16 with skunk stage 1 cams and valve spings and ret. but dont know if i should use it)
s300
gm 3bar
other stuff you can see in pics
will i hit my goal what should i change should i change my turbo will i need
sleeves to hit 450
Modified by texastype_r at 6:38 AM 9/5/2007
turbonetics 57trim
tial 38mm wastegate
s300
gm 3bar
sleeves to hit 450
You might want to go even lower on the compression ratio depending how much boost. And if you've got a built head, why not. Boost loves mods. And you might want to wrap that header or make a heat shield, cuz once everything starts heatsoaking, then you lose power and intercooler effectiveness
that turbo will be running out of breath around 450whp but should be able to make your goal....one thing i noticed that needs to be changed is your fuel pump. A 190 Walbro just isn't going to cut it...you're going to need the 255
Ah, ok cool. From that angle it looked like a single core rad.
You also might want to get some sort of crank case ventilation system (NOT the endyn kit: it'll spit oil all over). Otherwise you're going to have mega blowby.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88redrex »</TD></TR><TR><TD CLASS="quote">You might want to go even lower on the compression ratio depending how much boost. And if you've got a built head, why not. Boost loves mods. And you might want to wrap that header or make a heat shield, cuz once everything starts heatsoaking, then you lose power and intercooler effectiveness</TD></TR></TABLE>
really..............?
why would he need to go lower compression when he has every bit of ignition and fuel control from the hondata s300, hmmmm. this isnt a DSM and we dont need 7:1 comp ratio
mid 9s is perfect, it pulls away from a red light without falling on its face when the clutch comes out
we have the ability to tune well now, so low compression is not the band aid answer
the OP, sounds good except for the max efficiency of your turbo and power goals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texastype_r »</TD></TR><TR><TD CLASS="quote">SO WHAT WOULD YOU USE</TD></TR></TABLE>
I pm'd you what i'd use...what did you think??
i'm shooting for just over 400hp and i'm using the wiseco 10:1 flat top pistons
stock sleeves
stock sleeves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">T3/T67ho, GT35R, GT30R</TD></TR></TABLE>
for 400whp?? Those aren't very good choices. There are a lot better turbos out there for his power goal.
Honestly i would suggest the Silver Surfer, 60-1, possibly a GT30r, BW S256...i'm sure there are more, but it really depends on your use for the car. I keep thinking about fast spooling turbos that are going to be nearly out of puff past 450whp. Your best options IMO are either the Silver Surfer or a standard 57 trim....
you probably could make the power you want on the turbo you have now and still have pretty good spool times...the 60-1 is going to spool slower obviously and may not be necessary for your setup. Check out that link i PMd you about a little more because that might be the right fit for you...its not quite a 60-1 and not quite a 57 trim....you'd have good results w/ that turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texastype_r »</TD></TR><TR><TD CLASS="quote">stoopid tuned</TD></TR></TABLE>
best part of your setup haha guy's a damn genius
Change the pump to a 255 and wire it direct to the batttery for a Good 14v so that your sure it is getting perfect pressure. The turbo you have will make the power you want just fine, will start to max out soon but will make the power you want. If you looking to upgrade get a t3/60-1 or a gt3067r
FWIW, i prefer a mid 8ish:1 motor for big power on pump gas. I've tuned a lot of cars and i can always tell which ones are low comp, the plugs always look way better at that power range...
