What does headers do?
There will be a slight difference in sound due to the fact that the header is tubular steel, while the stock manifold is cast iron. The difference won't be terribly significant though.
this is honda-tech, the only person i know here with headerS on a civic is Civette
Noise wise, it will most likely be raspier especially with a hi-flow cat and a cheapo exhaust. Performance wise, on a stock motor power gains will be mediocre at best.
on my e-bay header it makes a *tick tick tick tick* noise because of the thinner metal like Padawan said... i really dont like it, it sounds like an exhaust leak, however it helps in the upper RPM range with power production.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta »</TD></TR><TR><TD CLASS="quote">on my e-bay header it makes a *tick tick tick tick* noise because of the thinner metal like Padawan said... i really dont like it, it sounds like an exhaust leak, however it helps in the upper RPM range with power production.</TD></TR></TABLE>
Doesn't do that on my friend's h22 accord swap with his ebay header..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">Doesn't do that on my friend's h22 accord swap with his ebay header..</TD></TR></TABLE>
There was a similar sound with my old DC Sports JDM 4-1, and it can be attributed to the fact that the tubing allows more of the valve noise to come through, which would otherwise be muffled buy the thick material of the stock manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAZARD_1310 »</TD></TR><TR><TD CLASS="quote">so it will make a slight noise, all my exhaust system is stock. the only reason I'm going to put the headers is, because it had the headers of a 89" crx.</TD></TR></TABLE>
that statement totally makes sense I understand fully
95_Civic_4dr
Dec 19, 2009 07:39 PM
