b series questions
Old Sep 4, 2007 | 05:36 PM
cars101's Avatar
Default b series questions
whats up h-t. i got my 91 crx hf 2 months ago and love how the car is except the slow single in it lol, but it runs real good so no complaints there. Anyway i plan puttin the car in for the winter and swapping a b18a1 into it or a b16. Either way i wanted to know what axles i will be using and can i use my original shift linkage. Also could i use the Ls rods,crank and piston in the b16. I know these questions are common but i want the right answers before i start this project. Some hints, tips and problems i will run into would be appreciated too. thanx
Old Sep 4, 2007 | 05:53 PM
GLI's Avatar
GLI
Default Re: b series questions (cars101)
Well if these questions are common maybe you should have used the red search button at the top right hand corner of the screen. But anyways you'll have to use different axles, which I don't know the type. Modified shift linkage, Hasport sells it with there mount kits. It probably wouldn't be such a wise idea to use the ls internals in the b16 block. The b18 block is taller then the b16, so I've heard. You'll need to buy an aftermarket cross member, maybe. Different steering knuckles, hell if I know which type. Maybe a obdo to obd1 conversion harness, depending on the engine year. Maybe a hydro to cable conversion kit, depending on the tranny type/year. Well if this is your first swap maybe you should do a d16a6 or a dohc zc. There bolt in engines just need to make sure if you do the dpfi to mpfi swap swap. If you do do the dohc zc try not to get a obd1 engine, like me. Then you'll spend months looking for a hydro to cable conversion kit, and then look for months for a obd0 si tranny, look for a obd0 to obd1 conversion harness and then finally do the swap. Good luck.
Old Sep 4, 2007 | 07:24 PM
pauld's Avatar
Default Re: b series questions (GLI)
OK This has been covered and covered, but here we go: You will want the axles and intermediate shaft from a 1990-91 integra, and you will need to change out the steering knuckles to any dx,ex or si spec civic/crx. you will need the shift linkage from a 1990 up integra, but have to cut and shorten the shift and stabilizer rods to fit, or buy aftermarket ones. Rather than your proposed internals swap, IMO you would be better off doing an LS/Vtec by using your LS block and internals with the B16 head. Its just easier, especially if you have a good running b18a to begin with. There is a good book written called "honda engine swaps" that has all the info you need.
Old Sep 4, 2007 | 08:55 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cars101 &raquo;</TD></TR><TR><TD CLASS="quote">i wanted to know what axles i will be using</TD></TR></TABLE>
'90-93 Integra. But you're also going to need DX/LX/Si knuckles, because B-series axles won't fit into HF/STD hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and can i use my original shift linkage.</TD></TR></TABLE>
No. You need either pre-fabricated swap linkage, or custom shortened '90-93 Integra linkage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Also could i use the Ls rods,crank and piston in the b16.</TD></TR></TABLE>
No. B16A/B17 blocks have a 7mm shorter deck height than B16B/B18 blocks.
Good Lord, use the <FONT COLOR="red">Search</FONT>
Old Sep 4, 2007 | 09:04 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GLI &raquo;</TD></TR><TR><TD CLASS="quote">Well if these questions are common maybe you should have used the red search button at the top right hand corner of the screen. But anyways you'll have to use different axles, which I don't know the type. Modified shift linkage, Hasport sells it with there mount kits. It probably wouldn't be such a wise idea to use the ls internals in the b16 block. The b18 block is taller then the b16, so I've heard. You'll need to buy an aftermarket cross member, maybe. Different steering knuckles, hell if I know which type. Maybe a obdo to obd1 conversion harness, depending on the engine year. Maybe a hydro to cable conversion kit, depending on the tranny type/year. Well if this is your first swap maybe you should do a d16a6 or a dohc zc. There bolt in engines just need to make sure if you do the dpfi to mpfi swap swap. If you do do the dohc zc try not to get a obd1 engine, like me. Then you'll spend months looking for a hydro to cable conversion kit, and then look for months for a obd0 si tranny, look for a obd0 to obd1 conversion harness and then finally do the swap. Good luck.</TD></TR></TABLE>
if you dont know the correct answers, dont friggan post such a long post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Good Lord, use the <FONT COLOR="red">Search</FONT> </TD></TR></TABLE>
this guy has been helping out a lot lately in the EF section.
Old Sep 5, 2007 | 04:19 AM
cars101's Avatar
thanx for the help and yea i totally forgot about the search button. As far as ls/vtec i dont wanna do that because i want to do it the right way but i dont have enough money to do it the right way. thanx again
Old Sep 5, 2007 | 06:57 AM
CRX Toad's Avatar
https://honda-tech.com/zerothread/1508680
BB6rude
Feb 4, 2008 08:07 AM
SoHc94
Jan 26, 2007 06:23 AM
hybridpatient95
Mar 16, 2005 03:14 AM
Supa_Slow_Civic
Sep 14, 2004 03:31 AM
Spoonedcivic
May 19, 2004 06:19 PM
