Hondata for Sale
Old Jun 15, 2002 | 09:38 AM
Armaan's Avatar
Default FS: Hondata Stage 4b (Brand New)
Hondata 4b + datalogging, w/ software, clutch switch, shift light, etc.
Pocket Programmer w/ software, power supply, etc.
ROM Emulator
P74 ECU modified for Hondata.
Brand New, never used, still in original packaging. Also have 3-Bar map sensor.
$900 + $80 for 3 Bar Sensor.
[Modified by 2.0L Turbo, 10:38 AM 6/15/2002]
[Modified by 2.0L Turbo, 8:22 AM 6/18/2002]
[Modified by 2.0L Turbo, 10:18 AM 6/18/2002]
Old Jun 18, 2002 | 07:22 AM
Armaan's Avatar
Default Re: FS: Hondata Stage 4b (2.0L Turbo)
ttt
Old Jun 18, 2002 | 08:20 AM
seen4ever's Avatar
what is the P74 ecu?? I know I have the p72 GSR one...
Old Jun 18, 2002 | 09:15 AM
dustin's Avatar
Hmm, the verbiage here looks oddly like my Hondata FS post that I posted a long time ago:
Hondata 4b w/ software, clutch switch, shift light, etc.
ROM Emulator
6 Alcatel eeprom chips
P72 (GSR) ECU modified for Hondata.
How does everyone have 6 Alcatel chips? I see everyone posting that they have exactly 6 of them......
That price seems ridiculously cheap.. That's over $1500 in stuff for $900... I have to question whether this is legit.
Old Jun 18, 2002 | 09:17 AM
Armaan's Avatar
Default Re: FS: Hondata Stage 4b (dustin)
Yup, copied your ad. It was perfect, and I am selling the same setup. Don told me that you were having problems with the Hondata setup you were running, Dustin. I'm going with AEM's EMS.
Old Jun 18, 2002 | 09:18 AM
dustin's Avatar
Whoa, well this is definately a good deal for the buyer then...
Old Jun 18, 2002 | 09:28 AM
LEON's Avatar
Youre selling because you heard that someone else has problems with the Hondata - I hope that's not the only reason.
The Hondata has worked great for me with no problems. I just wish that I waited a little longer to buy it so that I could take advantage off all you people selling yours for so cheap. Hey if your legit - someone pick it up, its a great deal.
Old Jun 18, 2002 | 09:30 AM
dustin's Avatar
Default Re: FS: Hondata Stage 4b (LEON)
Hondata works great, I had some minor issues with it but they were no worse than the minor issues I have currently with the EMS.
The primary reasons for my switch were 1) No burning chips w/ the EMS. 2) More features.
Hondata will maintain idle on a honda car better than any standalone engine management system.
Dustin
Old Jun 18, 2002 | 10:10 AM
Armaan's Avatar
Going with the AEM EMS because of reason #1. If I can't sell it for the $900 I want, I'll just keep it. Thanks for helpin' me out.
I still have to find a jumper which will allow me to use my non-OBD setup with the Hondata. Same deal with AEM; it's only available for 92-93 Integra. I have a 1991. Any ideas? Thanks again.
Old Jun 18, 2002 | 10:22 AM
dustin's Avatar
The easiest way to do that is to go to a junkyard and cut the ecu connectors off an obd1 integra/civic/prelude. Leave yourself a good 10" of wire. Then just strip and tap each wire into the ones on your factory harness (leave the factory ECU connector in place). Then you'll have OBD0 and OBD1 connectors in your car, and you'll be able to swap betweeen the EMS/Hondata and your factory ecu at will.
Hondata would be expensive for you too, since you'd need to go to an OBD1 distributor. The EMS will work with your OBD0 distributor.
Old Jun 18, 2002 | 11:21 AM
Armaan's Avatar
Yikes...that's a bit of work. Doug initially told me to buy a P74 ECM, which I did. He already "chipped" it for the Hondata I bought. Thanks for the help, Dustin. You da man.
Old Jun 18, 2002 | 11:26 AM
dustin's Avatar
Hmm, You'd need a conversion harness with the P74. P74/75 are OBD1 LS ecus.
Old Jun 18, 2002 | 12:41 PM
Armaan's Avatar
Where can I get the conversion harness?
Old Jun 18, 2002 | 12:42 PM
Armaan's Avatar
...or would it be better just to get a 1992 Integra? I need to buy a DA either way it goes because my 90 is pretty bashed up....I think I forgot to mention that.
Old Jun 18, 2002 | 12:43 PM
Solo2Vtec's Avatar
I have had the Aem EMS for about two weeks its great for the money!!!!
Old Jun 19, 2002 | 09:38 AM
KC GSR's Avatar
Default Re: FS: Hondata Stage 4b (Solo2Vtec)
so what exactly does it take to use that hondata 4b that you're selling on a 97 GSR? from the time you buy it, to the time its on your car and running, what else do you have to do?
Old Jun 19, 2002 | 10:22 AM
Armaan's Avatar
Default Re: FS: Hondata Stage 4b (KC GSR)
Nothing really. The system is Brand new, never used. You need to have your P72 ECM (97 GSR) "chipped" by Hondata. I believe the service costs $50. Other than that, your set.
Old Jun 19, 2002 | 02:08 PM
int3gra's Avatar
waynebennett77
Dec 31, 2012 09:34 AM
mbsi
Oct 14, 2008 09:53 AM
Brian_92GSR
Oct 6, 2002 06:04 PM
DSF
Jun 17, 2002 12:57 PM
01-0720
Feb 15, 2002 07:33 AM
