how to fool the obd2 ecu???
Old Sep 4, 2007 | 01:54 PM
joey1320's Avatar
Default how to fool the obd2 ecu???
ok i don't have a honda so i can't use crome, hondata and whatever other kind of ecu management honda has so i need to "fool" my ecu into thinking that everything is ok with the fuel trims on my toyota since i'm going turbo.
the ecu will need to see a good mixture a/f(14.7:1) so it doesn't go into limp mode or tries to lean out the fuel when adding boost. now the qestion is how can i do this?
i saw the o2 sensor simulators but the only ones i was able to find were only for the secondary o2 sensor to fool the ecu into thinking that the cat. converter is working properlly, just in case you have a bad one or a test pipe.
i need both o2 sensors simulated for the ecu to see a perfect working engine and then add the fuel with the piggyback computer(emanage, yeah i know you hate).
so does anyone know how i can do such a thing?
Old Sep 4, 2007 | 04:27 PM
Crx Jimmy's Avatar
Default Re: how to fool the obd2 ecu??? (joey1320)
why not use the new aem piggyback unit designed for obd2 cars? they dont have a plug and play for your car but you can hardwire it in.
jdreyer972
May 1, 2015 09:45 AM
joey1320
Sep 6, 2007 11:46 AM
Slammed_am
Jan 9, 2007 09:17 AM
FLIPboi
Sep 12, 2002 10:22 AM
