FS: T3/T67 aka "37R" turbo
tried this turbo this year since it seems to work so well on honda's and dsm's but it seems like subarus just can't spin it fast enough to get above about 30psi. the turbo is good for 700whp it is a 35r with a 40r wheel in it. it flows 75# a min. i have $1600 in it and i'll sell it for $1200 and whoever buys it can pick any hotside they want for it and thats how i will order my 35r then take the new hotside and put it on the 37r and take the 1.06 hotside off of the 37r and put on my 35r. the turbo has about 25 dyno pulls on it and 7 passes on it so its pretty much like new. this turbo made 18whp more than my 35r did at like 4psi less but because i can't spool it quick enough i am suffering in the torque department so i guess its coming off and i'm going back to something like i had last year just a little bit different. here are the specs of the turbo.
The T3/T67 H.O. is the latest ball bearing version of the incredibly successful T3/T67 turbocharger. Stuffing a true ball bearing T4 turbocharger into the T3/T4 frame, this is absolutely the biggest most powerful T3/T4 turbo on the market today!
Compressor Specifications:
-T04R 67mm compressor wheel with a max flow rate of 75 lb/min
-0.70AR T04S compressor housing
-Good to 700 whp.
Turbine Specifications:
-P trim turbine wheel
-0.63 or 0.82 A/R. turbine housing available
-4 bolt standard turbine discharge
-Good to 700 whp.
turbo m3
Feb 27, 2005 06:16 PM
